timing beltdmg4x4 04-28-2007, 10:29 AM im replacing timing belt and water pump on a 94 escort gt with a 1.9 i need info on how to set the timing marks... mightymoose_22 04-28-2007, 01:25 PM Hmmm... I thought GT's had a 1.8. Timing for the 1.9 is simple. With #1 on compression stroke, just line up the dots on the cam, oil pump, and crank. If done correctly, the crank sensor should be in line with the 9th tooth from the gap in the crankshaft sprocket. dmg4x4 04-28-2007, 06:05 PM your right it is a 1.8 is it still the same mightymoose_22 04-29-2007, 01:43 AM I believe it is still the smae... can't think of a reason it would be much different. THere should be timing marks on the crank and cam... just line them up. Make sure that ninth tooth is lined up too. dmg4x4 04-29-2007, 09:46 AM but it has a dual over head cam and there is two marks on the crank gear each cam has one mark mightymoose_22 04-29-2007, 03:04 PM Ok... For the cams, the mark will essentially go straight up... but you will see a notch cut out of the backing plate behind them. Line up the dots with those. For the crank, there is a timing mark on the block right behind the crank pulley. Line those up. Automotive Network, Inc., Copyright ©2012
