95 bonnie diesru1313 04-26-2007, 07:11 PM http://www.bonnevilleclub.com/forum/images/smiles/icon_lol.gif 95 bonnie, bought new, only problem was a uim, then the dreaded suddenly dieing, found your website, love it, took it to a cadillac dealer their top mechanic of 20 years said the ecm was bad 479.00 later still dying 1 month later still no luck yes 1 month, told them about all the grounds, fuses and everything else i found that others were having with the same car from your website the another 3 weeks later they found 2 problems, first a short wire harness above the steering colum had wires grounding out also the oil pressure sending had a wire grounding out also 875.00 later i'm going to pick it up tonight even the mechanic said he lost his butt on this one, buy the way i went to visit them one day and there were 4 mechanics 2 scanners 3 multi-meters trying to find the issue. wow what a relief.:banghead: maxwedge 04-26-2007, 07:39 PM Welcome to AF. So the ineffective repair , the pcm you paid for and did not the fix the car stays in there, what is their rational for that misdiagnosis. I'd insist they take it out and refund your money. Anyway, both these repairs are unusual, I hope this fixes the car, have my own opinion here. Good Luck and post back if you have any additional problems. jdq 04-26-2007, 09:03 PM Atleast make sure they give your old ecm back. ru1313 04-27-2007, 02:03 PM Welcome to AF. So the ineffective repair , the pcm you paid for and did not the fix the car stays in there, what is their rational for that misdiagnosis. I'd insist they take it out and refund your money. Anyway, both these repairs are unusual, I hope this fixes the car, have my own opinion here. Good Luck and post back if you have any additional problems. they fried the first one then found the short and no charge for the second. Jrs3800 05-02-2007, 12:41 PM What kind of stalling out are we talking about? When the car stalls does the Tach drop but all of the other gages remain functional? Such as the speedo? Does the car always restart? Does it stall out at all when cold or just after it has warmed up..? ru1313 05-02-2007, 06:02 PM What kind of stalling out are we talking about? When the car stalls does the Tach drop but all of the other gages remain functional? Such as the speedo? Does the car always restart? Does it stall out at all when cold or just after it has warmed up..? everything cuts out at once does not matter hot or cold check your wires. Jrs3800 05-02-2007, 06:43 PM Could be any of a few things... First check the Battery cables and make sure they are clean... There have been a lot of issues with the Positive cable.. And the cars systems are dependent on a constant 12v field... Thats a no cost check.. Also they may want to check all of the Ground Buses on both the driver and passenger side foot well as they do get wet and or at times corroded, this can cause all sorts of electrical issues as well.. Jagwar 05-03-2007, 11:52 PM I won't expound to the detail I did in another thread, but my '93 SE would randomly die while driving down the road... I swapped in a new (used from eBay) coil-pack (all 3 modules) and it's been fine since. wzvhyz4gm 05-15-2007, 04:08 AM Friday night at midnight I returned home from work in my trusty '95 SE. I parked in the driveway like usual. She wasn't driven for the remainder of the weekend until 46 hours later on Sunday night at 10 P.M. At that time, the first time since she was purchased new in Feb. '96, she wouldn't start. She's been perfect until now. Luckily, this happened while parked a home. What's strange is the problem occurred while parked in my driveway between Friday and Sunday night. The first thing I checked was to make sure my gas didn't get siphoned. The dumped about a gallon in the tank and the the gas meter reads about 3/4 full. Which is about where it was at when I parked the car Friday night. The starter turns strong and there's plenty of cranking power from the battery. All of the electrical system seems to be working correctly. When starting the engine I've always turned the ignition key clockwise and stopped at the "pre-ignition / electrical system on" position before turning the key fully clockwise to the run position to crank the engine. With the key in the "pre-ignition" position I'll wait for what I thought was the fuel pump running to inject fuel to the fuel injectors. Then after a second or two of the fuel pump running I'd turn the ignition key fully clockwise to the "run / cranking" position to start the engine. But this time I noticed I don't hear the "fuel pump" running when I turn the ignition key to the "pre-ignition / electrical system on" position. I don't know much about this vehicles ignition and fuel systems. I've never had a need to service a problem like this before in the past. But, I'm thinking maybe a blown fuse or defective fuel pump. There are no system error codes shown on the dashboard. Can you offer any suggestions / advice? Thank you, wzvhyz4gm ru1313 05-15-2007, 10:58 AM Friday night at midnight I returned home from work in my trusty '95 SE. I parked in the driveway like usual. She wasn't driven for the remainder of the weekend until 46 hours later on Sunday night at 10 P.M. At that time, the first time since she was purchased new in Feb. '96, she wouldn't start. She's been perfect until now. Luckily, this happened while parked a home. What's strange is the problem occurred while parked in my driveway between Friday and Sunday night. The first thing I checked was to make sure my gas didn't get siphoned. The dumped about a gallon in the tank and the the gas meter reads about 3/4 full. Which is about where it was at when I parked the car Friday night. The starter turns strong and there's plenty of cranking power from the battery. All of the electrical system seems to be working correctly. When starting the engine I've always turned the ignition key clockwise and stopped at the "pre-ignition / electrical system on" position before turning the key fully clockwise to the run position to crank the engine. With the key in the "pre-ignition" position I'll wait for what I thought was the fuel pump running to inject fuel to the fuel injectors. Then after a second or two of the fuel pump running I'd turn the ignition key fully clockwise to the "run / cranking" position to start the engine. But this time I noticed I don't hear the "fuel pump" running when I turn the ignition key to the "pre-ignition / electrical system on" position. I don't know much about this vehicles ignition and fuel systems. I've never had a need to service a problem like this before in the past. But, I'm thinking maybe a blown fuse or defective fuel pump. There are no system error codes shown on the dashboard. Can you offer any suggestions / advice? Thank you, wzvhyz4gm If you can't get answers from this website try bonneville club .com, there is also a lot of good answers on there also. azu 05-15-2007, 03:04 PM Friday night at midnight I returned home from work in my trusty '95 SE. I parked in the driveway like usual. She wasn't driven for the remainder of the weekend until 46 hours later on Sunday night at 10 P.M. At that time, the first time since she was purchased new in Feb. '96, she wouldn't start. She's been perfect until now. Luckily, this happened while parked a home. What's strange is the problem occurred while parked in my driveway between Friday and Sunday night. The first thing I checked was to make sure my gas didn't get siphoned. The dumped about a gallon in the tank and the the gas meter reads about 3/4 full. Which is about where it was at when I parked the car Friday night. The starter turns strong and there's plenty of cranking power from the battery. All of the electrical system seems to be working correctly. When starting the engine I've always turned the ignition key clockwise and stopped at the "pre-ignition / electrical system on" position before turning the key fully clockwise to the run position to crank the engine. With the key in the "pre-ignition" position I'll wait for what I thought was the fuel pump running to inject fuel to the fuel injectors. Then after a second or two of the fuel pump running I'd turn the ignition key fully clockwise to the "run / cranking" position to start the engine. But this time I noticed I don't hear the "fuel pump" running when I turn the ignition key to the "pre-ignition / electrical system on" position. I don't know much about this vehicles ignition and fuel systems. I've never had a need to service a problem like this before in the past. But, I'm thinking maybe a blown fuse or defective fuel pump. There are no system error codes shown on the dashboard. Can you offer any suggestions / advice? Thank you, wzvhyz4gm I have had this problem several times with mine. Each time it was a different problem. Crankshaft sensor, camshaft sensor, dirty grounds, bad wiring etc. Try the bonneville club, but do a search first. Lots of good info there! Good luck! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
