Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 5 Series
Old 04-26-2007, 10:18 AM   #1
jimbov
jimbov Normal reputation
Question E39 With intermittant engine power loss
I have an E39 530i 2001. It suffers from intermittant loss of power under acceleration and occaisonally slightly longer on the starter to start.
No Engine management fault is indicated but a DTC (Pcode) does exist in th fault memory. This is P0344 and, according to my manual, this is intermittant circuit of camshaft position sensor 'A'?
Is this the inlet or exhaust cam? are theses sensors a common fault?
Jim
jimbov is offline   Reply With Quote
Old 05-02-2007, 01:38 PM   #2
BAVARIANM
BAVARIANM Normal reputation
Re: E39 With intermittant engine power loss
P0344 is for the intake camshaft sensor. If that fault exists, the sensor is faulty.This is very common
BAVARIANM is offline   Reply With Quote
Old 05-06-2007, 03:06 PM   #3
jimbov
Thank you.........I will replace the sensor
Old 05-19-2007, 01:37 PM   #4
jimbov
Today I replaced the sensor and the car is fine again........many thanks.
Old 05-19-2007, 01:43 PM   #5
BAVARIANM
Nice
Old 05-20-2007, 12:35 PM   #6
jimbov
Unfortunately today the problem returned!
I read out the same fault code although it was pending.
I have today cleaned all the engine earth points but would like anymore suggestions
Old 06-03-2007, 03:27 AM   #7
sidewinder69
sidewinder69's Avatar
sidewinder69 0
With my '92 535I they had a common problem with the check valve for the fuel pump. (Hard to re-start after a quick shut down.) Solution is to replace the check valve.
It could also be the fuel pump, fuel filter(s), or even the injectors.
Try some fuel injector cleaner to see if that helps with the surging. Hopefully that's it.
But it doesn't seem so with the car throwing codes.
Damn computers.
Aren't you that kid my older brother used to throw dog shit at?
Beamer:
http://www.facebook.com/album.php?ai...4&id=761900240
sidewinder69 is offline   Reply With Quote
Bookmarks
Google
Web AF
