Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-25-2007, 10:17 PM   #1
cliffnuggets
cliffnuggets Normal reputation
Angry a/c light blinking 98 camry
Okay,
Yes I changed the magnetic clutch relay. Still the same problem. The air conditioner works for a minute, then the cold air stops and the light blinks (it taunts me).
cliffnuggets is offline   Reply With Quote
Old 04-26-2007, 07:47 AM   #2
DFBonnett
DFBonnett Normal reputation
Re: a/c light blinking 98 camry
How is the pressure? Have you cleaned the sensor connections?
DFBonnett is offline   Reply With Quote
Old 04-26-2007, 02:05 PM   #3
Mike Gerber
AF -Advisor
Mike Gerber Normal reputation
Have you checked the A/C belt for proper tension? The blinking can be caused by something as simple as a loose A/C belt slipping on the compressor. Once the belt slips, the compressor shuts down and the light blinks.
Mike
Mike Gerber is offline   Reply With Quote
Old 04-26-2007, 02:34 PM   #4
davemac2
AF - Advisor
davemac2 Normal reputation
there's a possibility it is low on refrigerant and the low pressure switch is cutting it off. Check for the A/C operation at the A/C amplifier:
http://www.camrymanuals.com/manuals/...nditioning.pdf pg 88
The A/C system pressure switch and cabin thermisistor come into this controller as well as engine temp ECT sensor and the output is the control to the A/C clutch relay. You can pretty well check A/C operation from there and then determine where the fault lies.
Electrical diagrams:
http://www.camrymanuals.com/manuals/99/99EWD.pdf pg 289
Don't know what engine you have, so there will be differences here.
The A/C clutch also has a 'lock sensor' that the A/C amplifier sees to make sure the clutch is engaged I guess. You need to check that too. It may be that the clutch is slipping and needs adjustment. If the controller senses this, it will shut the A/C down I think. As well, after a minute of A/C being on, feel the compressor and see if it has gotten really hot.
dave mc
davemac2 is offline   Reply With Quote
Old 07-23-2007, 09:55 PM   #5
stanleyeye
stanleyeye Normal reputation
cliffnuggets, did you solve your AC problem?
I met the same problem, and I have already replaced the drive belt, which doesn't work...
Thanks
stanleyeye is offline   Reply With Quote
Old 08-15-2007, 06:38 PM   #6
Mordacity
Mordacity Normal reputation
Thanks
Count me in on the same sinking boat, but it doesn't even give me a nice burst of cold anymore... it's just the taunting blinking light.
Mordacity is offline   Reply With Quote
Bookmarks
Google
Web AF
