2000, se, 2.4L...ho2s replacementgreenpunk 04-25-2007, 07:08 PM I need to replace the downstream o2 sensor and I'm wondering can I use a sensor from another vehicle, as long as it's heated? I tested the resistance of the sensor's heater circuit and it's different. Would this cause an effect that my pcm would identify as abnormal..ex - sensor warm up time? Any info would be great. Thanks. GTP Dad 04-25-2007, 07:26 PM The answer to your question is no! You need to use a sensor for your particular vehicle. If you don't your PCM will always give you a Check Engine Light. Spend the money and buy the correct one as it will save you in the long run. greenpunk 04-27-2007, 01:40 PM thanks Automotive Network, Inc., Copyright ©2012
