Testing the TPS on a B15elitecodex 04-25-2007, 06:46 AM Hey everyone! Im a new DIY-mechanic in the learning process :) I have an 2002 Sentra (1.8 model). I have an idle problem (idle is surging between 1500 and 2000 rpms). MIL is also on, so I got the code read at Autozone and it came back as P0510 which is a Close Throttle Position Switch Circuit. So I have this paper that tells me how to test the circuit with a multimeter between the TPS and the ECM. I have a Sperry DM-350a multimeter and am not 100% sure on how to properly test it. I dont want to screw up the ECM and I was told that if I do it wrong, then I can. So I suppose, here is my question list 1) Im testing for DC voltage correct? 2) What do I use as a ground? Will the car's frame/firewall be ok or does it have to be something specific? 3) What newbie mistakes am I bound to make that will potentially screw up my ECM? Sorry for the barage of stupid questions... I just don't wanna screw something up :) Thanks alot in advance!! 06chill 04-28-2007, 03:35 PM the frame or body will work fine......do you have a chart on how to test on this code or do you need one. elitecodex 04-28-2007, 09:13 PM I believe that I have it... but Im not 100% sure. Where could I find one just to make sure? 06chill 04-29-2007, 12:51 AM i work for a nissan dealer so i could get it from our assist wich is the computer program we use to work on them 06chill 05-02-2007, 04:14 PM Overall Function Check UBS001YY Use this procedure to check the overall function of the closed throttle position switch circuit. During this check, a 1st trip DTC might not be confirmed. WITHOUT CONSULT-II 1. Start engine and warm it up to normal operating temperature. 2. Check the voltage between ECM terminal 40 (Closed throttle position switch signal) and ground under the following condi-tions. 3. If NG, go to EC-984, "Diagnostic Procedure" . Condition Voltage At idle Battery voltage At 2,000 rpm Approximately 0V Automotive Network, Inc., Copyright ©2012
