96 Grand Am OBD code P0141
Rich Andrz
04-24-2007, 02:44 PM
Greetings,
I've gotten the code P0141 with my 96 Grand Am and have been told it is a problem with the wiring. It's my daughter's car and she had some idiot install a new stereo and I've found some wires not reconnected afterward. Does someone know which color wires go where?
Thanks in advance!
Rich
DONDIDIT
04-24-2007, 03:12 PM
you can do a search for gm cars audio wiring on yahoo.. and you should find it..
but jus to warn you.. 96 have crazy electrical issues.. that might not be the prob bob
justin0717
04-24-2007, 04:03 PM
A p0141 is an heated oxygen sensor (HO2S) code, A problem with the heater in the second HO2S. That probably has nothing to do with the radio. You probably just have a bad HO2S. Also if the stereo is aftermarket, There will be some wires not connected, most stereos will have a few wires that power things such as; a power antenna, or amplifier, or get power from a dimmer switch, either way there will be wires not connected.
xeroinfinity
04-24-2007, 05:01 PM
P0141 most likly is the downstream O2 sensor thats bad or the wiring could be damaged.
Rich Andrz
04-25-2007, 09:33 AM
Thanks to all....
I found that the disconnected wires are indeed the dimmer and another not used with the stereo. The codes were reset and I'll keep my fingers crossed next emission testing.
Rich
