Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 04-23-2007, 08:40 PM   #1
floodshill
floodshill Normal reputation
2001 battery light on, won't start in hot weather
On hot days, after a few short trips, the car won't start at all. The red battery light comes on and nothing happens until it cools down for at least an hour. The A/C hasn't worked in a couple of years. Could these be rrelated? Thanks.
floodshill is offline   Reply With Quote
Old 04-23-2007, 08:50 PM   #2
garync1
garync1 Normal reputation
Re: 2001 battery light on, won't start in hot weather
Sounds like the Alternator going bad, it is heating up under load and cooling down causing it to work again.. But my guess is in the next few days it will go.Also the battery is building it self back up a little as well. But if you keep this up the battery life will start going down.. Take it to auto parts place they will check the alt for you... FREE Autozone ,Advanced Auto and some NAPA's will check it for free. You want even have to pull it out..The AC could cause it if the clutch locked up. But you would hear a loud squall from the belt. So my guess is the Alt is just going..
garync1 is offline   Reply With Quote
Old 04-23-2007, 10:29 PM   #3
Ed_Strong
Ed_Strong's Avatar
Ed_Strong Normal reputation
Well, if you had that battery since 2001 I would also have it checked... The auto parts store can also check the battery to see if it's holding a load. Extreme heat and cold are a cars batterys worst enemy.
You could check if the alternator is not charging properly yourself with a voltmeter connected to the battery leads and while having a helper cranking you can monitor the batterys output.
At standby the volts should be at 12-12.5V. while cranking It should not sink below 9.5V (I believe) and should come back up to around 13.5-14V at fast idle.
Ed_Strong is offline   Reply With Quote
Old 04-24-2007, 05:16 PM   #4
lapin_windstar
lapin_windstar Normal reputation
Strauss (similar to AutoZone) were doing a $15 "electrical system check" recently, which checked the battery and the alternator. They might have done other stuff as well, but those were the main things. Of course, free is even better than $15, so...
lapin_windstar is offline   Reply With Quote
Bookmarks
Google
Web AF
