96 gmc yukon keyless remote
Mralcamo
10-15-2002, 07:41 PM
i have a 1996 gmc yukon. i lost my orgianl remote for it. i bought a new one off ebay. i was woundering if anyone new how to program my new remote. please email back
arliebright
10-22-2002, 07:23 PM
If you find anything out on the subject.... Let me know.. I have a 1996 Grand Prix that needs the remote programmed. I am just guessing that they will probably be the same way...:smoker2:
lojeti
11-08-2002, 09:07 PM
I have instruction on how to reprogram but i charge $1.30 email me at lojet@tconl.com
arliebright
11-10-2002, 08:27 AM
I'd send the money.. but your e-mail address is invalid.
jcpenny
01-26-2006, 11:11 PM
I also need help on reprogramming my remote for my 96 Gmc Yukon
thank you. IM going Really :screwy: Crazy tring to figure it out:banghead:
Pls send it to cubanlink07@tmail.com
Onblsht
02-06-2006, 08:08 AM
Transmitter Programming
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
Brian R.
02-18-2006, 01:48 AM
http://www.automotiveforums.com/vbulletin/showthread.php?t=8206
