02 cd player removal question
prototype80
04-20-2007, 11:05 PM
how do you get the dash apart to remove the cd player out of this model, i keep getting an error code when i try to put a cd in so i think one of my kids put a cd in with another cd already loaded. the cd indicator light is on but it wont eject anything, just keeps coming up witht he error code. I bought the car used and it didnt come with a owners manual so i have no way of telling what the code means. any help with this would be appreciated.
deerefeed
04-25-2007, 09:51 PM
What's the error code?
wesletj
04-26-2007, 04:17 PM
First disconnect the negative battery terminal then pull off the cover at the base where the console meets the A/C controls. Open the door just a little and then pull strait out (put you fingers inside the top of the door opening). Mine came out with ease. Then remove a screw or two (cant remember for sure) then pry the bottom of the molding off the peg next to the stereo (right side I think), then pull strait back, removing from the top of the dash. Be careful to not break the plastic tabs on the top going into the top of the dash. Then you can remove the stereo with 4 screws pull out a little then disconnect the antena and then the wiring harness. This can be done in less than 5 minutes. I have an 03 that did the same thing and went bad. I got one off of ebay for about $70.00. The dealer wanted $300.00 for a refurb and $500.00 for a new. They would not attempt a repair. Good Luck.
deerefeed
04-28-2007, 07:20 AM
The owner's manual doesn't indicate any error codes for the stereo. Assuming you have the single disc player when there's a CD in the player you can't put another one in. The laser eye may be dirty and it's not reading the disc. I had a fly crawl into one and die and that caused CD player problems.
perrenial151
05-01-2007, 07:39 PM
use PLIERS
