Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Corsica
Old 10-15-2002, 01:18 PM   #1
DJBeezle
DJBeezle
Question CD Player install
Does anyone know how to take apart the dash board and remove the radio because i have a Sony Xplod i really want to stick in there, i even got the Stereo kit so it will fit.. step by step? anything?
DJBeezle is offline   Reply With Quote
Old 07-14-2003, 04:30 PM   #2
Cyclone
Cyclone
Send a message via AIM to Cyclone
Dunno if you've figured this out yet or not but just pull the plastic panel off. Pull at the bottom under the AC and it should come right off and pretty easily might I add.
My system :: My website :: My forum :: My gallery
Cyclone is offline   Reply With Quote
Old 08-06-2003, 05:01 PM   #3
TechSys
TechSys
Send a message via ICQ to TechSys Send a message via AIM to TechSys
depending on the year of your car, there are 2 ways. I currently have a '90 so I can only help with anything below '91.
First you remove the black trim around the stereo and heater controls. There are 4 screws behind there that are, if I remember right, 7mm. Remove those four screws. Your radio is now ready to come out. Be carefull when pulling out as your heater/AC controls will also be pulled, there are hoses. You don't want to pull those off.
Now you say you've got the faceplate kit. since the stereo in the car is stock, you will also need the wiring adapter and antenna adapter. I have heard both can be bought at Wal-Mart. Scosche make both and the parts numbers are, GM02 for the wiring and MDA-1 for the antenna.
For others that have the same question about installing a stereo in a corsica. You need 3 thing, a faceplate, wiring adapter, and antenna adapter. Scosche make all three, and I believe Metra makes a faceplate also. The part number(s) for the faceplate is: GM1460 and GM1463.
The differance is GM1463 has a 1/2 din area above where the radio goes for things like an equalizer, the GM1460 doesn't
TechSys is offline   Reply With Quote
Old 09-24-2003, 03:37 AM   #4
crazybill5280
crazybill5280 Normal reputation
'91 and newer is real easy. Just pull the trim panel around the radio off (It snaps in place), there are two screws at the bottom of the radio, some are 5.5 mm some are 7 mm, then slide the old radio out, unplug it and put the new one in.
crazybill5280 is offline   Reply With Quote
Old 11-03-2003, 08:31 PM   #5
StoneCold316
StoneCold316 Normal reputation
Send a message via MSN to StoneCold316
Re: CD Player install
Try taking the panel off then taking 2 or more screws off than the deck just comes right out. The yellow is accessories, red is battery, black is ground(connect to a solid piece of metal), and wire up the speakers(that's pretty easy). *NOTE: If you switch red and yellow by accident your deck will work but it will restart every time you turn your car off.*
I know it from personal experience!
Good Luck!
StoneCold316 is offline   Reply With Quote
Old 02-15-2005, 03:09 PM   #6
wrangler88yj
wrangler88yj Normal reputation
Send a message via AIM to wrangler88yj Send a message via Yahoo to wrangler88yj
Friend of mine needs all the color codes for the head unit in a 94 corsica hope someone could help em here he wants to put a cd player in it
thanx
wrangler88yj is offline   Reply With Quote
Old 02-17-2005, 08:37 AM   #7
SilentAssassin2005
SilentAssassin2005 Normal reputation
go to autozone or pep boys or o'reiily and buy the Haynes manual for like $20 and it has everything you could ever think of in it....complete wiring diagram for everything imaginable
Tony Montana: Hey, Frank, you're a piece of shit. Frank Lopez: What are you talking about?
Tony Montana: You know what I'm taking about about, you f***ing cockroach.
SilentAssassin2005 is offline   Reply With Quote
Old 02-28-2006, 03:31 PM   #8
Fierc3 Kid
Fierc3 Kid's Avatar
Fierc3 Kid Normal reputation
Send a message via AIM to Fierc3 Kid Send a message via MSN to Fierc3 Kid Send a message via Yahoo to Fierc3 Kid
Does the stereo separate from the climate control unit?
Fierc3 Kid is offline   Reply With Quote
Bookmarks
Google
Web AF
