questions about map sensor and about manifold?
GSXBMX
04-19-2007, 06:51 PM
i have a 1995 200sx se-r and im going to be turboing it soon.my first question is...will the stock sr20det turbo manifold bolt up to my sr20de motor?my second question is...does my car have a map sensor or not?and if it does...can it handle 8psi of boost?any help will be appreciated...thanks a lot guys
fugiot
04-19-2007, 08:27 PM
1. Yes, the turbo manifold will bolt right up.
2. You must mean MAF sensor, and yes, it should handle about 12-15psi.
3. Careful with that stock tranny.
nismo_pilot
04-19-2007, 08:58 PM
there is a difference in map and maf sensors but i believe that if you have a NA sr20 right now it has a maf sensor as opposed to the map sensor
GSXBMX
04-19-2007, 09:24 PM
another question has come up along the way...how is the stock ignition system?can it handle boost or do i need to spend the money and get an external coil from MSD?
nismo_pilot
04-19-2007, 09:56 PM
eh i tend to lean towards doing things the right way, so i would do it, not to say it couldnt handle it but with as tricky as it can be to tune your turbos initial setup, i would want to be 100% sure i had reliable spark
slideways...
04-20-2007, 11:21 AM
id go the other way. ive never had a car where MSD was required. just make sure your stock system is in good shape and you should be fine. shit right now im building a 400 hp boosted ka24 and im gonna run the stock ignition system...only gonna upgrade the plugs with cooler platinum ones.
