Automatic Transmission, typical setting for in town?Gary W. Graley 04-19-2007, 04:16 PM Hello all, just got a new to me 2002 3.4L Alero, my first automatic tranny for a very long time, so I am wondering on the settings. When driving in town, having it in 3rd is ok? Will it do harm if left there for extended times/speeds? On the highway I would move it to D for overdrive. I know it sounds and is a simple question but I don't know the answer and don't want to mess up the engine but want to get the best/quickest response when driving this car. Thanks in advance, G2 BNaylor 04-19-2007, 05:34 PM You know it really doesn't make any difference but it is an automatic transmission. Let it do the work for you. Through the PCM module it will know when to shift based on the optimum conditions. The purpose of 4th gear - OD is to help improve fuel economy. Also, you need to be in 4th-OD for the TCC functions to work properly. I would not keep it in 3rd above speeds of 45 mph and over taching needlessly. Let the OD and torque convertor keep the best economy for you. I leave mine in OD even in city. IMO the 3400 SFI engine is a fairly good responsive engine in most driving conditions without having to manually shift. :2cents: Gary W. Graley 04-19-2007, 06:02 PM Thanks, that helps a great deal. Now, as I say, I've only had the car a couple of weeks, picked it up on March 30th, so my 30 days grace period is about over. Started out on a Friday, things went smoothly, come Sunday morning my family and I were stranded at the Church parking lot, battery flat out dead. Turned out had a dead cell, they replaced it no worries. Yesterday I took it in as the front brakes seem to chatter a lot, more than normal, they replaced all the rotors and brake pads, braking much better now. But on the way home, I heard more road noise than normal and when trying to turn right, the car wanted to straighten itself out. So I took it back this morning, needed wheel bearings on the front, they replaced the left one, and then the right was still making noise so they also replaced that one as well. I was a little annoyed when they said they noticed it when they did the brakes, but didn't think it was too bad, can't blame them for not offering I suppose. So, all is better tonight, handles well, road noise is down and braking is fine. But that made me nervous, one thing I didn't check, my fault for not looking at it, was the coolant tank to see if anything odd was floating around in the mix, well there are globules of gunk floating around and the opening was also gunked up...which makes me think there is a possible leak??? There shouldn't be "stuff" floating about in there. So I really hate to go back as the car is running ok now, but I worry that shortly it will present itself as an expensive repair and the remaining bit of the 30 days will be past. The car has 47k miles on it at present, I believe the previous owner kept it stored in a garage and didn't drive it all that much. Cosmetic wise, it's in pristine shape, but sitting for long times may have added to the bearing problem, but I'm only guessing at that. In all my other cars, I've never had to replace a wheel bearing, so the noise was new to me. Any thoughts on the above would be appreciated, before I drive back tomorrow and place my worries at the Service desk. G2 Gary W. Graley 04-19-2007, 07:09 PM Here are some shots of the coolant tank on this 2002 Alero I'm not sure exactly how to approach the dealership tomorrow concerning this... http://img.photobucket.com/albums/v130/GaryWGraley/Alero/coolant_cap.jpg http://img.photobucket.com/albums/v130/GaryWGraley/Alero/coolant_tank1.jpg http://img.photobucket.com/albums/v130/GaryWGraley/Alero/coolant_tank.jpg My feeling is that they should check why there is oil and correct the leak but I'm not sure that they will do it for free, it's still within the 30 days since purchase, so it should be covered, shouldn't it? Thanks in advance for your thoughts, G2 BNaylor 04-19-2007, 07:17 PM That is not good. You have Dexcool sludge possibly due to air in the system or the Dexcool is the original and plain no good. It should have been changed not later than 5 years or 150K miles, whichever comes first. A common problem on the 3400 are the LIM gaskets. I had mine replaced with the improved ones for free under warranty back in 2004. My reservoir is perfect and clean. No sludge. Bad LIM gaskets can cause the sludge. If you bought this from a GM dealer have them check the car records by VIN and see if the gaskets were ever replaced. Gary W. Graley 04-19-2007, 07:24 PM The car has 47k miles on it now, and I think it sat a lot of the time. So, you don't think it's oil, but this dexcool stuff then? I'll take it in tomorrow, of course they'll love me for that, but I think it should be addressed now, before it causes trouble. My only worry is, the car seems to run fine right now, so not sure how to bring this to them and have them do it within this 30 day warranty period. Thanks for your input, photos were taken with my new point and shoot Canon G7, nice camera, used a flashlight to light up down inside. G2 Gary W. Graley 04-20-2007, 09:13 AM Well, went to the dealership this morning, they checked the records, and claim the intakes were replaced just prior to my buying the car and that the brown gunk is from GM sealant pellets that they dropped into the tank and that it will slowly disperse and go away...of course that would be well after my last few days of the 30 day warranty period is up, any one know if the GM pellets produce such a brownish look??? Or is it some smoke being blown at me? Thanks, G2 BNaylor 04-20-2007, 09:25 AM I don't see why they used the sealant tabs if the revised LIM gasket was used. It is common practice for GM dealers to do this since a GM TSB addressed the issue but I don't recall whether that should be done with the improved LIM gaskets. Gary W. Graley 04-20-2007, 10:49 AM I can't say for sure, but I worry that they just said these things to appease me, as there are only 10 days left of warranty and then it's fully my problem. But, I think that before winter sets in, I'll have the coolant flushed out and set and see how it goes. Right now, the car runs great, love the look, ride and feel of it quite a lot, but whether that will comfort me with future repairs, I am not sure, I've been reading many things regarding the required upkeep on these cars. I know upkeep is a necessary evil, but these seem to be more problematic I'm just trying to switch to a more optimistic mind and hope my car doesn't run that path. 47k miles New battery new Rotors new brake pads new left and right front wheel bearings new rear speaker new fog lamps some are minor, but this will be my starting point and see how I go from this new slate, hopefully the chalk can remain in the box for a while. :) Thanks for you help and thoughts though! G2 jr6078 04-20-2007, 02:05 PM Gary, Sounds like the things you've had to have replaced so far are pretty normal routine maintenance items with possible exception to the axle (wheel) bearings, especially considering the mileage and age, which are both typically right at the point where the normal maintenance items start to really start needing attention. I've also had to replace most of these items on my own '99 that now has 121,000+ miles on it. I bought it with 87K on it, and I still love it. It's a good car for the most part and doesn't necessarily require any more (or less) maintenance than or have any more (or less) problems than a lot of other vehicles out there. The main thing I've found is to identify the items that you see on this forum as being primary concerns with the Alero model and keep an eye on them on your car. Good luck and enjoy your new ride! Gary W. Graley 04-20-2007, 04:30 PM Thanks, that's how I'm approaching this thing, keeping a good thought. Starting from square one and keeping an eye on things and doing a bit more preventive maintanence than I used to, and should have! G2 Gary W. Graley 04-23-2007, 06:10 PM Just a quick update, the ride is a blast, of course coming from the 4 cylinder world the v6 is way quicker ride, I'll have to be very careful about getting tickets ;) It rides great, I just have to put the other stuff behind me and look forward and keep on the preventive side of things and I think I'll be set, G2 db21 04-24-2007, 04:39 PM Given you need to drain the coolant system to replace the LIM gaskets it doesn't make any sense to me why there would be the stop-leak pellents in the coolant after the gaskets were changed. They would have replaced the coolant with nice clean stuff. I had the same brown gunk in my resevoir prior to changing out the gaskets...that is how it started...then I got coolant into the engine - check for white gunk around valves, look in oil cap. Then it led to a cracked head gasket... Don't want to worry you, but look around the site, the LIM gasket is probably the most notorious problem with those engines...there are a number of class action suits agains GM for it. Point being, I'd get to the bottom of the problem now while you have a chance, tough to do in the honeymoon phase of getting a new car, but better prudance now will pay for itself in the long run. Gary W. Graley 04-24-2007, 09:44 PM Good idea, I think I'll take it back and ask them straight out why they would do that. Personally, I think they figured they did enough to get it back into shape but man, if the engine goes, yikes, I really don't need that in a few thousand miles... It just seemed too pat that they changed out the LIM gaskets "the day before I took possesion" I mean, if they changed the brakes and noticed the bearings were bad, but since I didn't call them on it at the time, they didn't change them, they are not going out of their way to fix obvious things, but I know it's a business, but that seemed quite odd when I did bring it back the very next day and they said, yeah, we noticed that, ??? I think putting the rotors on brought the bad bearings into a real noticable range, when I was turning right, the growl was quite loud and if I let go of the steering wheel it would pull back straight very strongly. I have until the 30th of this month, not many days, but maybe enough to get them to flush it out, and watch to see if anything else gunks up! Thanks for the reminder! G2 Gary W. Graley 04-24-2007, 10:25 PM Well, I just went outside with a flash light to see if I could tell if anything had been done, and I did find what looks like a fresh bead of RTV around the top valve covers, so something happened recently. But I'm going to go back and ask them to flush out the system, the tank looks even worse now, heavy gunk! I looked in the oil opening hole and what little I could see looked ok no water floating on the oil... G2 Gary W. Graley 04-25-2007, 09:45 PM Went in today to voice my concerns and to see if they would flush the coolant Talked with the mechanic that replaced the seals and he seemed pretty competent, which makes one feel a little better about the work supposedly done. So, they agreed to flush the coolant out, Friday morning, which is cutting things pretty close for the 30 days warranty period, runs out on the 30th hmm or maybe the 29th! since I got it on the 30th of last month, there were 31 days there, so, that's even shorter, but, hopefully this will clear the tank and all should be well, we shall see! Thanks to all for your help and thoughts, G2 Gary W. Graley 04-28-2007, 01:51 PM Tank is clean, coolant flushed out and new coolant in place, now to keep an eye on it :) G2 Automotive Network, Inc., Copyright ©2012
