Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-19-2007, 02:46 PM   #1
timdillon
timdillon Normal reputation
1993 6 cyl Automatic Fuel Injector Problem
I've had them repalced and rebuilt. #1 (first one on the left hand side when you are facing the engine) keeps fouling out, I think it's the wiring harness or the computer. Car runs like crap. I want to fix and then sell the car. I don't want to screw the buyer. Any suggestions?
timdillon is offline   Reply With Quote
Old 04-19-2007, 05:32 PM   #2
davemac2
AF - Advisor
davemac2 Normal reputation
Re: 1993 6 cyl Automatic Fuel Injector Problem
why not just inform the buyer? You have obviously been chasing this problem for awhile. The fouling may be due to intermittent wiring as you already suspect or possibly due to a bad rebuild job, or maybe you have a leaky exhaust valve or gasket, or maybe contamination in your fuel system from corrosion (tank), bad filter? I would just throw in some injectors from a junkyard and see what happens. If you want to stay totally honest with the buyer, just tell them exactly what you have done and the history.
dave mc
davemac2 is offline   Reply With Quote
Old 04-19-2007, 05:36 PM   #3
timdillon
Its fine for a while then goes. I read some more on the web, could be the ECM/ECU. I'm going to try to locate and look inside ands see if it is corroded or has a burned smell. I'd like to get my money out of the car, it would be a hard sell if i tried to sell as is. Who wants to buy someone else's problem. But thanks.
Old 04-19-2007, 10:49 PM   #4
ice745
AF -Advisor
ice745 Normal reputation
Psychiatrists buy other people's problems.
I don't know much about fuel injectors, but is it possible to just swap the non-working one with a working one. (To save going to the junk yard). So say switch #1 and #2. Then see if the problem moves. If the #1 position still fouls, you'll know wire/computer. If #2 position starts fouling, you'll know it's the injector.
Edit:
Also if it is contamination in fuel system, is it at all possible a Seafoaming may help? At least as a cheap may-as-well-anyway attempt.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
ice745 is offline   Reply With Quote
Bookmarks
Google
Web AF
