Fuel Pump?
XtremePredictor
04-18-2007, 10:10 PM
I have a 91 Dodge Caravan AWD and i priced the Fuel Pump at Advance Auto and its $244.44. :banghead: Can Someone Please fill me in on a website or a cheap autoparts outlet/dealer. I know there is an alternative. PLEASE HELP!!! Its a 5 pin Plug. Really all thats wrong with the pump is the send line worked its way out of the plug in the top....but when i dropped the tank....my luck....the lines broke off with the hoses....if someone knew a place that sold just the send/recieve/breather plug that would save me a whole lot of cash....please HELP!!!!! Should i search for the part to replace on the assembly or just break down and buy the whole pump...the van has 205,000 miles and i just bought it about a week ago...heres a link for the pic of the pump http://www.partsamerica.com/productdetail.aspx?MfrCode=MST&MfrPartNumber=E7029M&PartType=52&PTSet=A
jsinton
04-19-2007, 06:58 AM
Here's one at Autozone, it's a little cheaper.
http://www.autozone.com/selectedZip,20740/initialAction,partProductDetail/initialpartType,00078/initialR,APP167807/initialvehicleId,2317502/shopping/selectZip.htm
XtremePredictor
04-19-2007, 11:43 AM
thanks thats alot cheaper than 244.44 :grinyes: i wish i could just fix the old 1 :icon16: but i know thats not gona happen
ronmar1
04-19-2007, 04:54 PM
I bought the one for my 95 caravan for $129.00 at the local Carquest. If all your's need are the the connectors, go to your local bone yard and get one, usually around $39.00 for a whole used assembly. The pump motors in those things are replaceable. You can use the one from the bone yard just replace the motor with yours'. Once you get the nack for changing those things out they're not a problem. With less than a quarter of a tank of gas I can change a pump out in an hour or less. You can even change out the plugs out and use a 3 connector on one that has a 5 connector and vice versa.
Ron
