Re: Getting fuel out of the tank
If the vehicle can run, just run it until it runs out of gas. But I'm guessing that isn't the case.
The 2nd time I dropped mine, the tank was about half full. I put a stack of 2x4s under each end of the tank to support it after the straps were removed. After the weight was on the 2x4s, I removed one from one end, then one from the other. Going back and forth there really wasn't much weight that ever needed to be lifted and it came down without a problem. Then just slide it out. If you are on rough concrete, put a rug or something under it so that the plastic doesn't rub.
Vinyl adds horsepower, right?
