Hi,
I have just joined, my name is Richard and I live on the south coast of the UK. I have a 88 Bonneville 3.8 V6 (vin code C).
The door sticker has worn away so could anyone tell me the factory tyre size for the 14" rims shown in the below pic?
it currently has 205/70/r14 rear and 195/75/r14 front, thse tyres arn't shown in the pic(old).
ALso I know my transmission (440-T4) needs a rebuild as it slips. Sometimes if i accelerate very gently it slips and there is no drive at all for a few seconds. Everytime i put my foot down the kickdown works ok, but it always then slips causing the tach to bury itself way past the redline. although in this situation it accelerates quite fast, but if i don't lift off the engine will probably die.
I figure that as it has 180,000 miles and previous owners didn't service it. a rebuild will cure this.
But my question is that it dosen't shift into 4th untill 55mph, but it should at about 40mph. will the rebuild fix this or is something else wrong?
oh, i changed the fluid (original fluid was very dirty but not burn't) and the tv cable and vac modulator are ok too.
thank you.
