95 caravan sliding door fell off
little sparrow
04-18-2007, 03:37 AM
Any one have problems with the sliding door falling off. Came off the guide rail on top and middle rail down the side of the van. Bottom rail still in the track. Rollers on middle one kind of worn. Jumped the tracks in those two places and cant seem to get it right to get back on track. Any suggestions?
Thank you
rseelen
06-17-2007, 11:40 PM
Did you find out how to fix this? My daughter just called and said her sliding door fell off on a 1993 Caravan. I have to look at it tomorrow and would like to know what to expect. I'm assuming the bushings or hinges broke and need replacement. Thanks.
ronmar1
06-18-2007, 07:14 PM
You'll have to un-bolt the roller bracket from the door, insert the roller back into the track, and then re-bolt it to the door. Check the rollers good before you try to re-install them. A little lube in the track helps also.
Ron
