No Fuel To injector!!!|WYG|SS 04-17-2007, 10:38 PM i had hit a rough dip and bottomed out and car died on me. i got water pump and oil pressure sensor replaced and water pump to. it says on the eletrical schematics that the fuel switch and oil pressure sensor are on same connector. my fuel pump fuse is good and not sure about relay How do i check the relay cause i dont want to go buy a new one. i read a lead that had some voltage i got going through it. how do i check if the fuel pump is bad? im not sure about the injector cause when i would have the key on my car on where instrament cluster lights would be on and i would hear a clicking noise coming from the top of the throttle body like around where the fuel injector is. |WYG|SS 04-18-2007, 04:09 PM i forgot to say that it isn't putting pressure in the line where u hear the noise when u turn the car into on position. is their like a cuttoff switch for fuel at all? |WYG|SS 04-19-2007, 09:25 AM i have found a test spot for the fuel pump and tried it and it didnt work. when i would turn the key on the relay would click. i have tested the relay and it is go so im going with a bad fuel pump. demo_deven 05-08-2007, 11:36 PM i have found a test spot for the fuel pump and tried it and it didnt work. when i would turn the key on the relay would click. i have tested the relay and it is go so im going with a bad fuel pump. Thats what I thoght in the beginning. Stupid J-body fuel pumps:@ A lot o problems I hve had with them lmao Automotive Network, Inc., Copyright ©2012
