rear break drums, can anyone help?
yvehc350
04-16-2007, 04:36 PM
on my wifes o2 there are 3 screws on the drum, I take them out and cant get the drum off. can anybody help me?
mightymoose_22
04-16-2007, 06:42 PM
These usually need to be taken off by inserting a bolt into one of the hold on the drum... the bolt will go through the drum and push it bree of the brakes. Alternately, you can try your luck with a heavy rubber mallet and see if you can get it to loosen up.
Of course... also make sure the parking brake is not on!
yvehc350
04-17-2007, 04:11 PM
Thanks, Ill give that a try.
Johnny Mullet
04-17-2007, 09:25 PM
Yeah! After removing the screws, whack it good to break it loose.
Bobbywolf
04-17-2007, 09:50 PM
Yep, there should be two threaded holes that you thread some bolts into. What happens, is that a lip forms on the inside edge of the drum, and hangs up on the shoes when you try to get it off. A big hammer can help as well. Turn the bolts a couple turns, give the drum a few wacks, couple more turns, repeat... They will come off.
