Spark plug housing or nuclear triggering device???
VanGuyII
04-15-2007, 10:51 PM
Alrighty then...I have a 2000 Honda Odyssey 3.5 V-Tech. I just had it in for 105,000 mi check up and was told that recommeded maitenance included changing the plugs (which they wanted $250 to do!).
So I says to myself, "Self, you've changed plenty of plugs in your day so why don't you just buy the plugs and do it." So, I checked out plugs online...not bad...~$11 for double platinums. Next step, check out access to the plugs...popped the hood and looked down at the engine block...HUH!?!?! I can access the "plugs" alright, but I have never in all my engines seen what I'm now starrin' at. Where there would normally be a cable and plug, I see little square plastic components anchored by hex-cap bolts with three conductor cable comin' off of each of 'em...(pause while scratching head with furrowed brow). So, being a curious monkey in part, I head for the tool box and come back with the necessary gear. Proceeding with caution...cable component disconnects easy enough...hex-cap bolt
is simple enough...grasping the component...twisting gently it slides out of the engine block. What I now hold in my hand appears to be a triggering component for a nuclear device! Attached to the backside of that boxey visible exterior is a black tube about 5' long and 3/4' in diameter. I'm assumin' there is a spark plug in there somewhere/somehow, but I can't see how the component comes apart. Now, I have no problem admitting when I'm in deep water, so I slide that tube back into the block, secure the anchoring bolt and cable clip, and then close the hood while saying loudly, "Well, that takes care of that...(just in case any of the neighbors happened to be watching what I was doing). So here's my question - can anyone enlighten me as to what I was holding in my hand...and is there a spark plug inside of it that I can replace myself??? Many thanks in advance for any insights shared.
FrodoGT
05-02-2007, 11:00 PM
The spark plug is down that deep hole. The heads on honda engines are very tall and the spark plug wires have that 5" tube on them to reach down in there.
VanGuyII
05-03-2007, 05:58 PM
Thanks...I recieved helpful input from others as well on this issue. Turns out tha each sparkplug has it's own coil, which is what each of those detinator looking tubes are. There are plugs down in them thar holes phersure! :grinyes:
wiseguy01
08-19-2007, 05:22 PM
its called DIS distibutorless ignition sytem. alot more expensive one of those coils cost about 250$ at aftermarket store
