Intake manifold swapmjzzs 04-14-2007, 10:03 AM I bought a 99 3.8 intake manifold and throttle body to swap the t.b. on my 96 3.3. I noticed that the manifolds seem almost the same. The 3.8 has a larger phlenum, I wondered if anyone has swapped a 3.8 intake on a 3.3? I did the t.b. swap last night, and made a nice peppy change, has bunches of get up and go now! I thought more volume would help even more. mjzzs 04-22-2007, 02:32 PM Well I did the swap yesterday afternoon. I swapped the upper intake manifold(plenum) only, the lowers were the same. Wasnt too bad of a job, tight space to work but pretty straight foward. Only problem was every little plastic vac line broke off, but I had some small rubber line to fix them with. Did a plug change while I had the plenum off..easiest one ever, just reach straight across, no contortions.:iceslolan The end result was well worth it, the van is like a new vechile, it just goes! Runs strong and no more lag while carrying a load, even up hills..had to go get 6 bags of mortar mix at 80 lbs each. Still fine tuning the idle etc, but Im very pleased with the end result. I feel like I have a sport van now! MdPhoenix 04-29-2007, 08:50 AM Great job! Glad to hear it helped. Tell me, what did it take to remove/replace the intake plenum? I need to replace the plugs on my 3.8 and don't know how to go about it. Automotive Network, Inc., Copyright ©2012
