1996 Hyundai Elantra Engine Rattling
mayville1
04-12-2007, 03:18 PM
I have a 1996 Hyundai Elantra with a 1.8 liter engine.
When i try to start the car there is a rattling noise and the car doesnt try to fire for a while. If i turn it over for about 20 seconds and pump the gas the car fires a little but doesnt start yet. Finally after about another 30 seconds the engine starts. While the engine idles there is a loud rattling noise and it sounds like its coming from somewhere inside the engine. When i push the gas peddle a little bit the rattling noise gets quieter but doesnt completely go away. When i drive the car and get a little speed the rattling noise goes almost completely away but i can still tell its there...
What could cause this problem?
-Main Bearings?
-Loose connecting Rod?
-Timing is off?
-Any type of gear inside the engine with possible broken teeth or something?
...what could most likely be the problem?
Has anybody had a similar problem like this and got it fixed?
THANKS, Nic
UncleBob
04-12-2007, 03:40 PM
you need to poke around with a stethoscope and narrow down where the sound is coming from. Could be as simple as a loose timing belt
mayville1
04-13-2007, 02:51 PM
k heres a not so wondeful thing about the car...:uhoh:
i have checked the oil in the dipstick before and it looked good and was almost full...but today when i checked where you put oil in it was milky white...(not so good anymore) :bananadie
so now im guessing the head gasket went and got antifreeze in the main bearings and the main bearings are shot (causing the rattling)...anyone agree???:popcorn:
:werd: ?
2.2 Straight six
04-13-2007, 03:01 PM
just because water got in with the water doesn't mean the mean bearings have gone. you'd need to pull the engine and remove the caps/crank before you could tell whether the bearings had gone.
you really need to narrow down where the rattling is coming from. it could be anything.
mayville1
04-13-2007, 03:12 PM
yeh good point...but it does increase the possibility...
yeh i def gotta figure out where that noise is coming from tho...that would help...maybe my dad can figure it out (i hope) :)
UncleBob
04-13-2007, 03:13 PM
some condensation is quite normal....drain the oil and see if its contaminated before you make too many assumptions
mayville1
04-13-2007, 03:17 PM
ooh so thats prob why it doesnt show up on the dipstick and only on the fill cap...but yeh ill check that out...
THANKS every1
2.2 Straight six
04-13-2007, 03:56 PM
maybe you've just had a little water drip around the cap, and there isn't actually any in the sump.
i've seen it on cars at college, water/condensation around the filler cap, so you get the white "mayonnaise" there, but when you drain the oil it's fine.
