Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Exterior / Wheels / Tires
Exterior / Wheels / Tires This is the place for all exterior modifications including wheels and tires.
Old 04-11-2007, 05:42 PM   #1
95firebird
95firebird Normal reputation
ok why wont these rims fit
i got them off a 99 trans am they worked fine on his watched him take them off. i have a 95 the fronts go on perfect but not the backs why is this
95firebird is offline   Reply With Quote
Old 04-11-2007, 06:26 PM   #2
92zcamaroperson
92zcamaroperson's Avatar
92zcamaroperson Normal reputation
Re: ok why wont these rims fit
how wide are the back wheels? 11" wide wheels require some encouragment on the fenders part
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
92zcamaroperson is offline   Reply With Quote
Old 04-11-2007, 06:27 PM   #3
92zcamaroperson
so i understand anyways
Old 04-11-2007, 06:39 PM   #4
goldz28
goldz28 Normal reputation
You might need a BFH to take care of the problem
goldz28 is offline   Reply With Quote
Old 04-11-2007, 06:45 PM   #5
95firebird
what is that and where and how much are they
Old 04-11-2007, 06:49 PM   #6
goldz28
BFH is a Big F%^#%*& Hammer
Old 04-11-2007, 06:52 PM   #7
95firebird
hahaha lmfao well i have one of those lol but some one told me that i can grined the rims center hole but will that make so they wont fit on a new trans am cuz i plan on getting a 98+ when i turn 18 and want to put thoses rims on it
Old 04-11-2007, 06:56 PM   #8
goldz28
What is causing the hold up?
Old 04-11-2007, 07:03 PM   #9
95firebird
when i put the on the back they are not going on right i didnt notice and i drove ithe car and the drum is all lose and it moves and makes noise and the car drives funny the fronts work fine i put the old rims back on the car drums are not lose and works just fine
Old 04-11-2007, 08:39 PM   #10
92zcamaroperson
where is the wheel hitting. thats what you need to find out. all wheels on all of the 93 to 2002 f-bodies should interchange without any problem. Dont grind the center...i dont see how that would even help
Old 04-11-2007, 09:22 PM   #11
poormillionaire2
poormillionaire2 Normal reputation
What are the specs of the wheels and tires you are trying to mount? Are they the stock wheels or some sort of aftermarket that you got off the newer f-body? They should all fit though.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
2009 Kawasaki Ninja 500R
poormillionaire2 is offline   Reply With Quote
Old 04-11-2007, 09:54 PM   #12
95firebird
no they are stock 5 spoke chrome rims i called pontiac and they said that the wheel studs were longer on a 98-02 and i would need to replace thos inorder to get the wheels to fit right what do yall think about that
Old 04-11-2007, 10:08 PM   #13
giddyup50
giddyup50 Normal reputation
It's obvious, I'm no bird/maro expert. But what Pontiac says makes sense. When you have the new wheels on are the same amount of threads on the studs sticking out as when you have the old wheels on? I would start there before getting a Big F#$%^&* Hammer or grinding on the wheel. Do some more investigation before you do something you'll be sorry for. I would look into the shorter/longer stud situation first.
giddyup50 is offline   Reply With Quote
Old 04-11-2007, 11:38 PM   #14
goldz28
If your not rubbing on the inner wheel well no need to modify it. Its got to be something easy to fix. With out seeing it its hard to see exactly whats going on.
Old 04-12-2007, 02:22 AM   #15
blindeyed
eBay aDdict™
blindeyed's Avatar
blindeyed Normal reputation
Send a message via AIM to blindeyed
Best way to explain this, is for you to visually compare your current rims with the new ones you got. The newer 97+ rims have a hub centering ring around the center opening, which the 93-96's don't. all you have to do is get a dremel and smooth down the hub ring so that it will slide on.
Here's some pictures, the lighting sucks, so try to bare with me..
>> 93 - 96 style, notice how the hub opening is very smooth
>> 97-02 style, see how there appears to be a little lip in the opening. That is what needs to be ground down. Works best if you use a dremel.
EDIT: And as for fitting on a newer 97-02 after grinding the center.. Yes, they will still fit perfectly fine with no problems.
- Jason
1995 Pontiac Firebird ..........................
1995 Geo Prizm
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
blindeyed is offline   Reply With Quote
Bookmarks
Google
Web AF
