Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '71-'87 Civic / CRX
Old 04-11-2007, 04:02 PM   #1
msmallz
msmallz Normal reputation
86 CRX - Replaced Fuel Pump, Problem persists but different
If you'd like to see the problem I was having then go to this thread:
http://www.batauto.com/Forums/index.php/topic,1285.0.html
So, I had a fuel pump already so I decided to go ahead and change it out. The car ran beautifully for about a week. Then the problem came back but it has been different. Before, it would only happen usually in the evening after being driven then sitting for a while. When it would happen it would stumble, I'd give it gas which would rev it up, but then it would die and not start until the next morning.
Now, the problem doesn't come at a specific time, it just pretty much always happens. Now, it will fluctuate from about 1100-900 RPMS and if I don't give it gas it will keep fluctuate at lower and lower RPMS down to about 300 to 500, but, it hasn't died on me. Now, when I give it gas it will rev up and stay revved up unlike before. If I drive it for a while then when I let off the gas at a light or something, it will stay normal for about a minute or so before starting to act eratic. If I keep it revved over 2000 RPMS it will stay pretty normal, but below that it will start to stumble.
I'm getting married in two weeks and this car is causing way more stress than that! I guess maybe the fuel pump was going bad and making the problem worse, but now I don't know what to do. Does it point back to the carb now? Are there any other diagnostics I can run or should I just give up and take it to the shop?
msmallz is offline   Reply With Quote
Old 05-25-2007, 11:19 PM   #2
mad_steez
mad_steez Normal reputation
Send a message via MSN to mad_steez
Re: 86 CRX - Replaced Fuel Pump, Problem persists but different
I would look for any cracked or disconnected vacuum lines, did you check your PCV? It sounds very similar to a problem i was having with the 2bbl Rochester on my Chevy, i found a cracked line and rebuilding the carb may not be a bad idea. If you have time you should take it off and take it apart and see if the gaskets are still good.. I replaced the lines and rebuilt mine and it's been trouble free since. BTW did you try some carb cleaner?
mad_steez is offline   Reply With Quote
Bookmarks
Google
Web AF
