basic auto 101 questions
grasshopper
10-13-2002, 12:20 PM
okaaaaayyy, you guys are the "bomb" right??
so be a pal and answer some or any of these q's
I.D. 8 ways engines are classified.
Identify 2 major byproducts of combusted gas.
what is "vaccum" and how does it relate to atmos. press. and how it is measured
explain effects of compressing gas
identify parts of "valve train": function,location and method of lubrication
xplain valve movements as they relate to the 4 strokes of engine oper. and firing order
2 major diff. between gas and diesel engine
basic purpose of timing chains and gears, and engine gaskets.
what is engine bearing clearance and how is it measured
advantage of offset piston pin location is...
whats accomplished when a camshaft is timed?
define cam ground piston, blow by, and flash point
how is compression ratio determined, measured, and what its effects are on efficiency and emissions.
6 funtions of lubricating oil.
4 diff's between gasoline and diesel fuel
thats all folks!!!!!
Fly Rice Racer
10-17-2002, 08:42 PM
Are you taking a test for an autoshop class or something?
YoKramer
10-19-2002, 09:17 PM
Im not exactly sure what you mean by that.
Co, CO2, Oxygen, Hydrocarbons, NOX (oops)
Vaccum in an engine related sence is less than atmos. pressure.
Strokes of engine Valve movements
Intake - Intake valve is open as pistion reaches just BTDC
Intake valve is closing as pistion reaches BDC
Compression - Both Valves are closed pistion returns to TDC
Power - Spark plug fires BTDC Both Valves closed
Exhaust Vlave opens just BBDC
Exhaust - Exhaust Valve closed just BTDC
Intake/Exhaust valve overlap
Less electronics on a Diesel Engine
Way the A/Fmixture is combusted (Gas Spark/ Diesel Compression)
Better Engine Perf. by letting the valves open at the best time for the most power
blow by is whne the piston rings are worn out and combustion byproducts go past the piston
Clean, Cool, Lube, Seal ( i know the other 2 but cant think of em)
Have you ever been to WyoTech? cause i recognize alot of those questions off of some of our tests but its been about a month since ive been thru that Course ... lol
redimpss5
12-20-2002, 07:23 PM
if its for a test, you forgot most diesels are two strokes.
