93 altima p/w problemssliderny369 04-09-2007, 05:57 PM the drivers side window works, other 3 dont. any ideas? MOSSMAN50 04-11-2007, 06:56 PM not sure, but maybe you have a wiring problem. it would be odd that all window motors burn out at the same time. i had a similar problem with my mustang when i had it, and it ended up being a wiring problem connected to the window button. i know it isn't much to go on, but i hope it helps. perrenial151 04-25-2007, 08:47 PM Check fuses first. get a wire diagram and check for power going to the switches, then power to the motor. You can also put 12 volt power to each motor just to be sure they are not burned out. Toolman5523 05-22-2007, 07:47 PM Sounds like your main switch may not be providing pwr to the other switches, either that or you have the window lock switch "on". FixUrNissan 05-22-2007, 11:14 PM do you have the window lock button on? catkoot 06-16-2008, 07:43 PM I have the same car 93 and the same issue . All not working exept the drivers side and it happened one window after one . U can hear Little noise when u press down but the window won't move down !!! Automotive Network, Inc., Copyright ©2012
