Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 04-09-2007, 07:14 AM   #1
l.brook
l.brook Normal reputation
1997 E36 Compact Oil Filter Question
Hi,
I'm new to BMWs and have been stuggling to carry out the simple task of changing the oil...
I understand the filter is a not a disposable cartridge style one but a housed filter and is located under the bonnet/hood - however, I can't work out which canister the filter housing is.
There only seems to be one that it can be - the only other canister reads ATF oil which I assume to be gear/power steering oil.
This leads to my second problem - if this is the oil filter housing, how do I take it apart - shouldn't it have a ratchet/nut top or perhaps a screw down the middle? Do I need a boa-constrictor style oil filter wrench to unscrew the top?
Also, if I do open up the housing, will the oil spill out if I don't drain the sump first with it being at a similar level to the sump?
Thanks,
Louis
l.brook is offline   Reply With Quote
Old 04-09-2007, 01:16 PM   #2
CassiesMan
CassiesMan's Avatar
CassiesMan Normal reputation
Send a message via AIM to CassiesMan
Re: 1997 E36 Compact Oil Filter Question
Oil filter/dump is undeneath the car, not up in the engine bay. Unless they've changed it from the E36-E46, the pan, filter, and all that good stuff is at the bottom of the motor.
CassiesMan is offline   Reply With Quote
Old 04-09-2007, 01:38 PM   #3
l.brook
Is that right? I've read a few guides suggesting it is up in the engine bay? I can't see anything undreneath the car resembling the filter housing. Can anyone confirm this?
Thanks,
Louis
Old 04-09-2007, 01:58 PM   #4
CassiesMan
CassiesMan's Avatar
Every time I've had the oil changed, they are underneath the car. Its under a little cover that you have to take off. I can't really explain it with out pictures, but it is underneath the car.
Bookmarks
Google
Web AF
