98 Grand Cherokee 2.5 turbo dieselPaulKing 04-07-2007, 07:36 PM Hello everybody here from Portugal, Ho knows how the purges the cooling system, of the ZG; when hi opening the deposit of the water appeared me it seems to be rust over the water. The ideia is to remove all the water and put new cooling liquid. jeepgclwj 04-07-2007, 10:41 PM There should be a drain plug at the bottom corner of one side of your radiator. Slowly open when the engine is cool. Drain out old and put in new but make sure you close the drain plug first.... Good luck.... PaulKing 04-09-2007, 12:34 PM There should be a drain plug at the bottom corner of one side of your radiator. Slowly open when the engine is cool. Drain out old and put in new but make sure you close the drain plug first.... Good luck.... Thanks Automotive Network, Inc., Copyright ©2012
