Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Prism
Old 04-07-2007, 05:55 PM   #1
rekd0514
rekd0514 Normal reputation
Lightbulb Horn + Cruise Control not Working
Like I stated, both of these are not working and I have a good feeling that the problem is in the wiring behind the steering wheel airbag. I have a 1998 Chevrolet Prizm. Anyone know how to remove this easily so I can have a look at what the problem might be?
rekd0514 is offline   Reply With Quote
Old 04-16-2007, 10:11 PM   #2
rekd0514
Re: Horn + Cruise Control not Working
I still need help figuring this one out if anyone has any tips.
Old 04-21-2007, 10:29 AM   #3
dugan50
Authorized Vendor
dugan50's Avatar
dugan50 Normal reputation
Hello:
A Geo Prizm is a Toyota built vehicle. You are probaly correct in assuming the probelm with your car is a damaged 'clockspring'. This component may or may not be available by itself and should only be purchased from the dealer. A used one may geive you more trouble than you already have.
To diassemble it, you will need to
1) disconnect the battery and wait 10 minutes
2) unbolt the airbag (2 - 30torx bolt on the sides through acces holes)
3) remove the wires attaching the airbag to the column
4) remove the steering wheel (MARK THE POSITION THE WHEEL WAS IN)
5) remobve the steerong column covers
6) remove and replace the clockspring attached to the multifunction switch
Installation is the reverse procedure
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
dugan50 is offline   Reply With Quote
Old 04-21-2007, 10:47 PM   #4
rekd0514
Sweet! Thanks.
Bookmarks
Google
Web AF
