Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Cars in General > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-07-2007, 01:40 AM   #1
KiwiBacon
KiwiBacon Normal reputation
Parts for an IHI RHB6
Does anyone know of parts availability for an IHI RHB6?
I'm looking for a compressor wheel. I'm not too fussy on exact spec (trim etc) as I have a spare housing I can machine to fit.
KiwiBacon is offline   Reply With Quote
Old 04-08-2007, 12:01 PM   #2
2.2 Straight six
That thing got a Hemi?
2.2 Straight six's Avatar
2.2 Straight six 0
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Parts for an IHI RHB6
have you called IHI to see if they can provide the parts you need?
usually these companies provide an aftersales service so you can get replacement parts if need be.
Seatbelts Saved My Life
2.2 Straight six is offline   Reply With Quote
Old 04-08-2007, 08:13 PM   #3
KiwiBacon
Emailed IHI a few years back. Parts are out of production.
Old 04-09-2007, 04:35 AM   #4
2.2 Straight six
2.2 Straight six 0
ahh. the only other thing i can think of is to look for a car that came with that turbo and go searching the scrap yards. or phone up a company that remanufactures turbos and see if they have the wheel you want.
Old 04-09-2007, 04:50 AM   #5
KiwiBacon
Already done that. I'm hoping someone might come up with a remote pattern part manufacturer or a bolt on equivalent from another brand.
Old 04-09-2007, 05:07 AM   #6
2.2 Straight six
2.2 Straight six 0
i'm no expert on IHI turbos, so i guess you'll just have to take measurements of wheel size etc and try find a similar one from someone like Garrett. from what my friends tell me, they're very good about spare parts and stuff. it may be worth giving them a call.
is there something special about this turbo? or do you just want to use it because you already have it?
Old 04-09-2007, 05:27 AM   #7
KiwiBacon
Even with a rooted compressor wheel it gives about 30% less exhaust backpressure than a T25 for the same boost on the same engine.
So I'd like to get it working properly and see what it can do.
I'm faced with (probably) a similar cost to rebuild (bearings) a T25 I currently have or find a new compressor wheel for the IHI. Both will only be a temporary measure (1 year or so) but will be a backup once removed.
I have a habit of always taking the "more interesting" approach.
Old 04-09-2007, 05:43 AM   #8
2.2 Straight six
2.2 Straight six 0
what gives it the low exhaust back pressure?
Old 04-09-2007, 05:50 AM   #9
2.2 Straight six
2.2 Straight six 0
Did a quick search on the turbo, found which cars came with them stock:
ISUZU MPR Truck '88-'92 IHI RHB6-A
Mazda 626 '83-'83
Mazda MX6 (1st gen)
Fiat Spyder '81-'82
that's what i could find. looked for info on rebuilding them but found nothing.
Old 04-09-2007, 06:02 AM   #10
KiwiBacon
Mazda 626 '83-'83
Mazda MX6 (1st gen)
Fiat Spyder '81-'82
There're two others as well Diahatsu Rocky turbo diesel and some Yanmar stationary engine.
The wheel is 59mm OD with a 6.7mm bore. The back is flat, whereas a garrett T28/T3 wheel has a dish to it. No doubt I can machine one from a T28/T3 wheel, but my gear isn't accurate enough and it'd need rebalanced afterwards.
Old 04-09-2007, 06:27 AM   #11
2.2 Straight six
2.2 Straight six 0
we have a company here that does lots of custom turbo work, making turbos and machining and balancing parts.
if you want, i'll find out their contact details and you can see if they can make you the right wheel.
Old 04-09-2007, 06:53 AM   #12
KiwiBacon
Thanks for the offer, but there are plenty of turbo shops here too capable of the work.
I just found out the VF39 and other such turbos (WRX) have a 60mm compressor wheel. Anyone know the shaft size?
Old 04-09-2007, 07:32 AM   #13
2.2 Straight six
2.2 Straight six 0
looked, all i could find was something that said it has a T3 shaft. but i'm guessing that size is manufactureer dependant and that you wanted size in mm.
Old 04-11-2007, 02:33 AM   #14
Hit_N_Run-player
Hit_N_Run-player Normal reputation
Send a message via AIM to Hit_N_Run-player
do you have a pic of the wheel exactly you need? Trim? Inducer/exducer diamter? Shaft size?
I used to rebuild IHI turbos frequently and probably have a wheel around here or could get you one.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Hit_N_Run-player is offline   Reply With Quote
Old 04-11-2007, 02:49 AM   #15
KiwiBacon
I don't have a handy pic, the spare wheel I have suffered severe dust erosion and is mostly gone.
Here are the measurements.
Exducer 59mm
Inducer 36-39mm (hard to measure on an eroded wheel)
Shaft 6.7mm
Wheel length 24.4mm
Bookmarks
Google
Web AF
