Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo/Passport
Old 04-06-2007, 01:35 AM   #1
Ramblin Fever
Ramblin Fever Normal reputation
What else can *feel* like bad rotors??.....
Just in the last few days, starting to feel something odd in the brake pedal of the Rodeo; but not all the time.
I can remember in my '91 Rodeo, warped rotors were always an issue, and the typical sign was slight vibration in the brake pedal during stops.
Well, in the '97 Rodeo, I'm getting a VERY, very slight vibration in the brake pedal, but ONLY when trying to make faster stops from a fast speed; i.e. coming off the highway, with a short off-ramp and red light.
Normal driving/braking, I don't feel it; I know brakes & brake system are fine, that's all been triple checked in the last 6 mnths.
However, rotors are 10yrs of age & original with 170k miles - still look fine though.
Also, I do know that my 2 front tires are not 100% balanced, very close, but I'm very sensitive to the feel of them, and know that they're not right on target. So, I'm also wondering if it's actually the tires I'm feeling??
Any ideas are appreciated.
FWIW - I've also started taking different routes to/from work, on streets I don't normally drive on.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Ramblin Fever is offline   Reply With Quote
Old 04-06-2007, 06:31 AM   #2
Kaobb
Kaobb Normal reputation
Re: What else can *feel* like bad rotors??.....
I had somtething similar to that on my 1993 Rodeo 4WD. It turned out to be one of the U-joints. I think there is like 3 under there ......check them all. One could be causing it.
This may not be what is causing your issue but it is worth checking out before spending hundreds of $$$$. A u-joint is probably $10 to $20 bucks.
Good luck.
k
Kaobb is offline   Reply With Quote
Old 04-06-2007, 08:41 AM   #3
amigo-2k
Isuzu Guy
amigo-2k Normal reputation
a weak piston in the caliper?
amigo-2k is offline   Reply With Quote
Old 04-06-2007, 09:52 AM   #4
Ramblin Fever
You know, I've been wondering about a u-joint issue on this truck, cause every now and then I will also get a mild thud/bump from the rear, but it does not happen at the *same* time as a shift in the tranny, which leads me to believe it's not the tranny and something else.
I will check the piston's in the calipers too.
Thanks!
1997 3.2L V6 Rodeo
Old 04-06-2007, 08:10 PM   #5
surferfletch
surferfletch Normal reputation
I'd say you've described my braking on original rotors at 161K. I'm doing the front rotors when I do pads all around this summer.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
surferfletch is offline   Reply With Quote
Bookmarks
Google
Web AF
