Gauges arent lighting up....
david22585
10-11-2002, 11:57 PM
I have a 2002 Explorer Sport, and the other day my vehical was stolen and recovered. The aftermarket radio I had was stolen, same with my amp and system. Now ever since then, my dashboard gauges, HVAC, and radio lights wont light up. The display for the radio station works, but it wont light up for night time. Any ideas?
fordman123
10-14-2002, 09:31 PM
You might want to check fuse 30 (a 15 amp fuse in the side of the dash driver's side)
If that is good, then depending on the options,
you either have a faulty park lamp relay, a bad dimmer switch, a broken wire, or a bad ground. If you are handy with a voltmeter, let me
know and I will try to guide you through it.
Good luck
Fordman
dgeer
12-22-2004, 10:31 PM
just wondering if you got this fixed...my 98 has the same problem....
busa_4
12-24-2004, 11:24 AM
when they stole the radio they probably damaged wires. check the wires going to the radio.
2talll
12-25-2004, 02:15 PM
Would a fuse possibly be the problem with the light for my gas gauge just going out on my? I know when a light bulb burns out it happens when the light goes on- with the gas gauge the light just died out while I was at a stop light.
