Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 04-03-2007, 12:02 PM   #1
TheRod730
TheRod730 Normal reputation
2002 GrandAm GT 6 cyl replacing battery
I have a 2002 Pontiac Grand AM GT 6 cylinder. I need to replace the battery. Is it a pain in the a$$ for this particular model? Anything of importance I should know before going ahead?
TheRod730 is offline   Reply With Quote
Old 04-03-2007, 04:52 PM   #2
Gir-_-
Gir-_-'s Avatar
Gir-_- Normal reputation
Send a message via AIM to Gir-_-
Re: 2002 GrandAm GT 6 cyl replacing battery
wrong forum but its ok, it'll prob get moved....
you'll need I think a 13 or 15mm socket to take out the piece that holds the battery in place.. an extension works well and when taking off the battery connections... black first then red... and I think those use a 8mm or 10mm but I could be wrong
make sure you get the same battery
99' GRAND AM SE V6H.O. 188fwhp and climbing!
Gir-_- is offline   Reply With Quote
Old 04-03-2007, 05:41 PM   #3
Vipey1337
Vipey1337's Avatar
Vipey1337 Normal reputation
Send a message via AIM to Vipey1337
I don't know if the GT is different than the SE, but my SE was incredibly easy to change and put in (including rewiring my audio system). The only "hard" part was getting my new cold air intake around my battery
Mods:
P&P LIM/UIM, angel eyes, CAI, lowering springs, struts, plugs, wires, flowmaster 2.5" catback exhaust, front/rear strut bar, synthetics, DHP PCM
Vipey1337 is offline   Reply With Quote
Old 04-04-2007, 08:50 AM   #4
xeroinfinity
out saving the world
xeroinfinity's Avatar
xeroinfinity Normal reputation
This is for "helpful tips, maintenance guides and R&R procedures"
NOT to ask questions
I like ...... a High Five!
Ok I moved it.
Its pretty easy to replace the battery.
One bolt on the pole side of the battery down low.
10 mm socket to remove the bolt on the block ,
it probly will have to be completely removed.
It might also be rusted and hard to turn, try some spray lube
If you have the stock air box it might be tight but should come out .
And the Ram air shouldnt be in the way either.
All GAs are the same from 86' and Up !
Oh ya, remove the Batry terminals.
Hope that helps.
1999 Grand Am SS & Grand Am GT 3.4 OHV
Who'd ever thought the "G" in GM would stand for Government Motors.
xeroinfinity is offline   Reply With Quote
Old 04-04-2007, 11:25 AM   #5
Vipey1337
Vipey1337's Avatar
make sure to unplug the wires FIRST!!!!
Mods:
Bookmarks
Google
Web AF
