98 pathfinder wont start after stero installeddie2003 04-02-2007, 10:26 PM Hi guys, im really hopeing someone can give me some advice on what do do. I installed an amp 4 new door speakers and a headunit today and after i put everything back together i went to start it but it just wont turn over. I have tried everything. it seems to me almost as though there is a kill switch perventing the car to start. Has anyone have any ideas what to do here?? Thanks! Eddie denisb 04-03-2007, 07:22 AM You didn't drain your battery by chance by leaving door open while installing or lights (turning them on accidently) etc. If not, check your main power connection where you tapped in your amp and head unit. You could have cut a main wire. Check fuses, you might have shorted something not knowingly poping a fuse. Check fuses under the dashboard and if there are fuses under the hood check those also. Also fuse links if there are any(not sure on the 98s). Denis Automotive Network, Inc., Copyright ©2012
