Re: 1988 4x4 Blazer Amp wire
dont really know about an '88 but in my '95 i just cut a hole in the rubber gromet that the antenna wire goes through, and ran my amp wire through that also, then under carpet to back on the jimmy....
and im pretty sure an '88 would have antenna wire going through firewall also :P
DO NOT run it from the fuze box if the amp is going to be more than 60watt's the wires that go to the fuze box are exrememly thin, and the risk of a fire is extremly high if you do this...wilsons10 try running your amp for 20mins then feeling the wire harness on the inside of your fuze panel....guarantee it wont pleasent...i know theis personally, as i have a spotlight on my jimmy and i just popped the wire into the fuzebox and when im rabbit hunting at night and the spotlight is on for an hour or so the wires almost feel mushy...and the spotlight is only 100w
*traded in*1995 gmc jimmy, 4dr, 4x4, vin w
PERFORMANCE: ebay-chrome intakes air intake, magnaflow cat converter, flowmaster 40 muffler, electric fan, high beam headlight relay, accel 48,000v super coil, ADS high performance chip.
*new ride*2004 pontiac sunfire
PERFORMANCE: K&N typhoon intake, b&m shift plus, copper springs for plug boots, lightweight (3oz) alt pulley, thats all for "now"
