Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-28-2007, 11:41 AM   #1
Ducaire
Ducaire Normal reputation
S10 has plenty of oil, but oil pressure is low
Yesterday as I was pulling in the driveway, I noticed the "Check Gages" light was on, and looked and saw that my oil pressure was almost at the bottom.
Well today I checked the oil, and it was well above the add mark, and it was a goldish brown color, so it's pretty new oil. (1'500 miles since my last oil change; always change my oil every 3'000 miles).
In the past when I'd crank up the truck, when the engine was cold, the oil pressure would go up to about halfway between '40' and '80'
(seen here)
When it gets warmer, it goes down to a little above '40'.
(seen here)
But now when I start it, it starts out halfway between '40' and '0'. Could my oil pump be bad?
Ducaire is offline   Reply With Quote
Old 03-28-2007, 06:34 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: S10 has plenty of oil, but oil pressure is low
Usually it is a oil pressure sending unit problem.
But you need to put a manual oil pressure test gauge on it to find the true pressure.
A electric gauge is only a indicator gauge.
Post back what you find.
MT
MT
MT-2500 is offline   Reply With Quote
Old 03-28-2007, 09:58 PM   #3
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
MT
I agree the sending unit is the most likely problem, but why not just change that out for under $10 and see if the guage returns to normal parameters before doing a manual oil pressure test. A manual oil pressure guage, or a trip to the mechanics to test it will cost a lot more and will probably point right back to the sending unit, and how often is the average person going to need a manual oil pressure guage in his lifetime.
ericn1300 is offline   Reply With Quote
Old 03-29-2007, 10:03 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
That procedure might save you a few dollars but could cost you a engine.
If you want to do proper testing and see what the true oil pressure is you will need to put a manual test gauge on it.
Anything else or just throwing parts at it is a hit and miss.
MT
MT
Old 03-29-2007, 11:20 PM   #5
redwheeler
redwheeler's Avatar
redwheeler Normal reputation
you cant just go throwing parts at cars and hope they work doin it right the first time is always cheaper
remember you can go to autozone and borrow tools so you wont have to buy a guage
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
redwheeler is offline   Reply With Quote
Old 04-08-2007, 08:16 PM   #6
Ducaire
Thanks all. Yes, twas the sending unit. Costed $99.82 to have it replaced.
Old 04-09-2007, 10:04 AM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
You are welcome and .
Thanks for posting back how it went.
Did they check the actual pressure on a test gauge or just throw on a sending unit?
MT
MT
Bookmarks
Google
Web AF
