3400 V6 SFI LIM Gasket Procedure
BNaylor
03-28-2007, 11:55 AM
Here is a helpful link one of our members posted concerning performing a lower intake manifold gasket replacement on the GM 60 degree engines. This is applicable to both the 3100 VIN "J" and 3400 VIN "E". 1999 and up Alero and Grand Am has the 3400 SFI VIN "E".
Click here (http://d-tips.com/General/Articles/Default.aspx)
Revised torque pattern and torque values for LIM bolts.
Engine Oil or Coolant Leak (Install New Intake
Manifold Gasket) # 03-06-01-010B - (10/24/2003)
Engine Oil or Coolant Leak (Install New Intake Manifold Gasket)
2000-2003 Buick Century
2002-2003 Buick Rendezvous
1996 Chevrolet Lumina APV
1997-2003 Chevrolet Venture
1999-2001 Chevrolet Lumina
1999-2003 Chevrolet Malibu, Monte Carlo
2000-2003 Chevrolet Impala
1996-2003 Oldsmobile Silhouette
1999 Oldsmobile Cutlass
1999-2003 Oldsmobile Alero
1996-1999 Pontiac Trans Sport
1999-2003 Pontiac Grand Am, Montana
2000-2003 Pontiac Grand Prix
2001-2003 Pontiac Aztek
with 3.1L or 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1)
This bulletin is being revised to change the model Information. Please discard Corporate Bulletin Number 03-06-01-O10A (Section 06 - Engine).
Condition
Some owners may comment on an apparent oil or coolant leak. Additionally, the comments may range from spots on the driveway to having to add fluids.
Cause
Intake manifold may be leaking allowing coolant, oil or both to leak from the engine.
Correction
Install a new design intake manifold gasket. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. When replacing the gasket, the intake manifold bolts must also be replaced and torqued to a revised specification. The new bolts will come with a pre-applied threadlocker on them.
Notice
An oil leak may result if the vertical bolts are not tightened before the diagonal bolts.
Diagonal bolts may require a crows foot to tighten.
Tighten
1. Tighten the vertical lower intake manifold bolts (1) to 7 N.m (62 lb in).
2. Tighten the diagonal lower intake manifold bolts (2) to 7 N.m (62 lb in).
3. Tighten the vertical lower intake manifold bolts (1) to 13 N.m (115 lb in).
4. Tighten the diagonal lower intake manifold bolts (2) to 25 N.m (18 lb ft).
