Hey there everyone. I thought I would take a few moments to express my thanks to those in the forum that provided me input on my intake gasket fix, so thanks richtazz, crazy jim, LA1. For those of you that are thinking of doing this job yourself and don’t have a lot of experience, the best words of advice is to be organized. Get yourself a cheap Haynes Impala manual (42048). Take pictures before you start each process of tear down to give yourself reference for re-assembly. Make sure you have all the tools needed organized. Label all of your connectors and hoses. Give yourself plenty of space for putting and cleaning parts. Buy all your fluids, pipe compound and anti-seize (for spark plugs) at the same time you get the gaskets to avoid more trips to the parts store that will slow you down.
I got the car fixed with only a couple of hitches along the way (besides having to work as well as do the car). Since feedback is a good portion of this site, I thought I would give you a quick rundown of my progress through it..
Here is a picture of the engine before the tear down.
Negative batter cable disconnected. Fuel pressure relieved (thanks tazz). Coolant drained. Remove top radiator hose, cross vehicle brace, coolant overflow tank, alternator and alternator mounting bracket.
Remove air filter and ductwork. Remove throttle and cruise control cables.
Label and remove any more connections for the wiring harness and set it aside.
Remove coil pack, plug wires, power steering pump (set it aside) and coolant bypass pipe. I was able to get mine out without having to take off either of the top motor struts.
Remove EGR from upper intake. Remove upper intake. Take care to keep all brackets held on by the intake, with the intake. Use a plastic bag.
Remove fuel lines. 9/16 SAE on back rail and No. 27 torx for front rail (remove the fuel sensor retaining clip from the fuel rail and keep it with the torx bolt). Remove valve covers (for the back you need a 5/16 SAE with a 1/4 inch drive and 2" extention to fit beside the coil pack mounting stud). Remove thermostat (not shown). This will make it easier to get the lower intake off.
Loosen the fuel rail mounting bolts (to allow room to get to lower intake bolts). Remove lower intake. Loosen bolts 1/4 turn at a time to avoid warping the intake. This picture was also very helpful in the re-assembly. You can see that the pushrods are paint coded for easy identification. Exhaust (6" long) are marked bright orange and intake (5 3/4" long) are light orange. If you do what I did (cleaned pushrods thus removing paint) this picture could be a life saver. Its also possible to identify where the intake rods go by looking into the lower intake chambers. As you can see, where the fuel is drawn in, its clean. The direction of the mark is the location where the intake rods should go.
This is a picture of where my leak was. Drivers side back water jacket. You can see how the silicone gasket is all warped and falling out of the plastic allowing coolant to exit the intake around the angled bolt. It also was deteriorating the RTV on the block seal. Coolant is still visible on the block right under where the intake would be.
This was about the time I had to go to work and I forgot to take pictures of the push rods removed. For reference, I would also also take a picture of the table where you have the disassembled parts. Then if you are missing something you can identify where it could be.
And here is the final product.
I have checked for both oil and coolant leaks and have not found any. Although my car still stinks like coolant when it gets warm. Hopefully that will eventually burn away. So there you have it. Total cost for FelPro gaskets, Gastrol Syntec 5W-30, AC Delco oil filter and Murry + thermostat was around $150 or so. Less than $200 for sure and my car is back on the road.
I hope this post and pictures might help the next novice out!
Jim
