Smoking/watery Exhaust
bigt61
03-26-2007, 10:25 PM
I have a 98 Rodeo, just purchased. Before I bought it, it had been sitting for over 2 years in storage. Previous owner not sure what maintenance/problems it has had. Knew it had a bad trans .
replaced the trans.
Now, the engine smokes like crazy. It doesnt do it at first, but after it gets hot or I step on the throttle past idle, white smoke comes out of the exhaust and water pours and drips out of the tail pipe.
I can see no evidence of oil in the coolant, or water in the oil pan.
I am thinking it has a head gasket blown, but I have read about issues regarding the IM leaking.
Which do you guys think the problem is?
amigo-2k
03-26-2007, 10:29 PM
blow head or cracked head (cracked heads on +98 isuzu's are not that common, but I've read the 98-99 had a bad run of heads that crack more often).
bigt61
03-26-2007, 10:39 PM
So, should I get a newer head off a newer 2000 or up engine, or will I be safe to have a machine shop machine the heads and replace them myself?
If I could have a bad run of heads, doing the work wont fix it because it will happen again, right? or is that just a fluke that I have a bad one?
