Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-26-2007, 07:44 PM   #1
paisan247
paisan247 Normal reputation
Lost !!! Need some help with 88 s10
I have a 1988 chevy s-10 2.5 standard.
the truck started stalling a coupleweeks back. it usually happens when the truck warms up (after driving around for a bit) and only stalls when given gas. it got worse. it starts hard and when i do get it started it runs like its running on one cylinder and the catalytic converter glows orange. i tryed many things so far. heres what i changed
plugs- didnt work
wires-didnt work
distributor cap-didnt work
rotor-didnt work
throttle position sensor-worked better but still putts and stalls after warming up
fuel filter-nothing
fule pump-nothing
then i was told to change the hall effect sensor in the distributor. changed it today and the truck started right up ran beautiful and did not stall at all when given gas. drove it around the block a couple times parked it in the driveway shut it off. went to start it back up and wouldnt turn over. when it finally did i got the same problem as stated above.
IM LOST. i would drive it into a tree but i would probably hurt myself more in the process. ANY HELP WOULD BE ABSOLUTELY WONDERFUL!!!!
paisan247 is offline   Reply With Quote
Old 03-29-2007, 09:37 PM   #2
twistedtech
twistedtech Normal reputation
Re: Lost !!! Need some help with 88 s10
First thing I want to say is the timing is out. It is running late. Did you get the wires mixed up? Are the plugs on the injectors mixed up? Did the chain jump?
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
twistedtech is offline   Reply With Quote
Old 03-30-2007, 08:28 AM   #3
paisan247
Rechecked wires. firing order is correct and wires are going to proper plugs. there is only one injector and it sprays fine. someone said it might be a fuel pump shutting down when it gets hot starving the engine for the proper amount of fuel but giving it enough air causing it to also run lean and heat up the converter. does this seem logical? thanks for the reply
Old 03-30-2007, 10:27 AM   #4
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Verify correct fuel pressure of 11-13 PSIG. Even though the pump and filter are new, the FPR could be dropping pressure. The lean mixture/hot cat converter theory is plausible. There may also be restriction in or after the converter.
Blue Bowtie is offline   Reply With Quote
Old 03-30-2007, 10:02 PM   #5
drdd
drdd's Avatar
drdd Normal reputation
sounds like you have a clogged catalytic converter.
rotten egg smell is also a sign of a clogged cat
if you get under the truck (when it's off and cold) and hit the cat with a rubber hammer, do you hear anything rattling inside it?
plugs- didnt work
wires-didnt work
rotor-didnt work
fuel filter-nothing
fule pump-nothing
drdd is offline   Reply With Quote
Old 04-01-2007, 02:55 PM   #6
paisan247
NO RATLLES AND NO EGG SMELL.......IT RUNS BEAUTIFUL FOR 5 -10 MINUTES AND THEN STARTS TO PUTTER AND CHOKE WHEN IT GETS WARM.....IF U HIT THE GAS IT STALLS OUT AND WILL NOT START AGAIN UNTIL IT COOLS DOWN..
Old 04-01-2007, 09:07 PM   #7
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
You need to verify the MAP is working properly, giving you correct values. In my onpinion, this sounds like a O2 sensor, and/or a ECM going bad too. Its hard to verify these things without a scanner, and a scanner has its limits on older vehicles too.
blazes9395 is offline   Reply With Quote
Old 04-01-2007, 10:01 PM   #8
drdd
drdd's Avatar
I'm no expert but, how could a glowing orange catalytic converter be anything other than the cat clogging? (which would restrict the exhaust and cause the heat to build)
Yes there could be other issues related to fuel mix, o2 sensors and such but a glowing orange cat ... gotta be some kind of physical blockage ...
no ?
Old 04-01-2007, 10:48 PM   #9
blazes9395
Newbie mod
blazes9395's Avatar
Usually a glowing cat is a result of overloading it, and overloading a cat is usually a result of too much unburnt fuel getting to the cat. Now yes there could be damage to the cat causing blockage, further causing it to overheat and self destruction eventually occuring.
Bookmarks
Google
Web AF
