92 lumina apv-a/c heater control-speedo
[signtext]Boy do I need help with this! Everything was working fine. Took a 10 mile drive, a/c worked and speedometer working. After getting in to drive home, went crazy. Fan blows only on floor, cant turn fan off using off button, but can change speeds, no cold air, light indicating fan speed doesnt work, and the speedo never moved off zero. And the cruise didnt work either. After getting home, saw the ignition fuse was blown. Put in a new one, started her up and the new fuse started to melt! 15 amp like it should be, got very hot and soft. Before I noticed the fuse heating up, turned on a/c, started blowing out of the vents,and the little fan speed light came back on, but no cold air. Didnt drive it so dont know about speedo and cruise.Everything else seemed to work.Sounds like more than one problem to me.What does this fuse control? It started and drove with it blown. Is the a/c compressor gone? HELP!!3.1 auto
I am back with new info Tried new fuse, ok, tried heater fan, ok, tried a/c, ok, but not cold, compressor did not engage. Wiggled connection to compressor, tried again, now cold, compressor engaged, fuse ok. Am still concerned with the hot fuse I had. Also the connection seemed fine. Will pull it off and try to clean. Any ideas out there? Am pretty good with physical things that can be seen but electrical loses me. Nick in SC
