Alternator belt tensioner...TonyG362 03-24-2007, 03:24 PM I have a 94 Honda Passport and I replaced the alternator belt, but when I went to tension the new one the bolt snapped. Now I need a replacement but I can't find it anywhere and nobody even knows what it's called. It's a bolt that goes through a bracket on the alternator and is held in place by a retaining pin. It screws into a metal square which is bolted on the engine block, so when you back the bolt out it pulls the alternator back tensioning the belt. Anybody have any idea what this part is even called or where I might find it? I've tried the dealer already with no luck also. surferfletch 03-24-2007, 03:57 PM Local hardware. There are a couple of posts on this. Just bring the snapped bolt with you... Solster: I thought you were sending me one from Hawaii??? trooperbc 03-24-2007, 05:46 PM is it pictured here? this is from the official isuzu online parts site www.myisuzuparts.com (http://www.myisuzuparts.com) it comes in handy because you can print out the illustration to show the parts guys what you want. unfortunately parts lists more likely than not don't give the bolt specs. //bc http://www.myisuzuparts.com/images/Trooper%2092-97/Print/0-33a.gif TonyG362 03-25-2007, 06:12 PM You are awesome thanks! Yes it looks like it's numbers 81 and 96. I can't believe I didn't know about that site before, it could've helped me so much in the past. Thanks again. Automotive Network, Inc., Copyright ©2012
