95 cirrus runs rough when humid or raining
Google
Web AF
montgomery820
03-22-2007, 11:32 PM
my 95 cirrus lxi runs very rough and is hard to stay running only when it is raining or very humid. otherwise the car runs great. does anyone have any ideas? i changed the plugs, wires. dist. cap and rotor, replaced radiator, motor mounts, air filter, cleaned the throttle body, valve cover gaskets, oil, master cylinder, and probably a few other things.
crashdummy51
06-16-2007, 11:20 AM
try checking fuel pressures. Also, replace fuel filter! Chances are, your dist is failing, very common problem, in these cars. let me know.
Crashdummy
montgomery820
11-08-2007, 11:02 AM
It was the distributor. thanks! easy fix.
jennajohnson
11-16-2007, 01:22 PM
My 98 chrysler is having the exact same problem, do I need a new distributor cap or just a new distributor, or do I need both??? Montgomery which did you replace to get your car started again?
Google
Web AF
