91 accord what order to bleed brakesnolo 03-22-2007, 03:11 PM I have people say to bleed the farthest from the MC, but I was reading somewhere that it should be bled in this order. Passenger rear, driver front, driver rear, passenger front. I have been going passenger rear, driver rear, passenger front, driver front. Which one should I do? jeffcoslacker 03-22-2007, 05:20 PM AllData's recommendation: Wheel Bleed Sequence: If you are bleeding the brakes manually, the sequence is RR-LR-RF-LF. If you are pressure bleeding, bleed the front brakes together and the rear brakes together. I can see advantages to either way. I go as described above... Automotive Network, Inc., Copyright ©2012
