grand prix pcm programmer
06grandprix
03-22-2007, 11:38 AM
ok here is my problem just got this base model 2006 grand prix with the v6 3800 series III motor i have been looking all over the place for a handheld pcm programmer u know the ones that dont require a laptop. the only one ive found is the diablo sport programmerand it says its for the gxp. will this work for my motor? if not does ne 1 know of another place i could get one that will work?
BNaylor
03-22-2007, 12:27 PM
I noticed you had another post within the past 10 days on the same issue. Please do not start a new thread and run multiple threads on what appears to be the same issue or question. If someone has the answer they will respond. If not then you will most likely not get a response due to the nature of your situation.
http://www.automotiveforums.com/vbulletin/showthread.php?t=683151
I would highly recommend not tickering with programming your PCM module if the car is still under any manufacturer's warranty. And even if you were to find a power programmer for your year and model Grand Prix it probably won't do any good without mods unless you plan on doing simple programming like removing the top speed limiter, etc. :2cents:
BTW - The old thread has been closed since you have this one.
