Water pump-95 BlazerBryanCa 03-20-2007, 05:21 PM Any special tips on replacing the water pump on my 95 Blazer that anyone could share? I see that I'll have to remove the 4 bolts from the fan..anything I'll have to watch out for? There is a note on the frame stating there are air bag sensors in front of the radiator. Will this be a problem when doing this repair? Thanks old_master 03-20-2007, 09:41 PM The only thing that may present a problem, if you're not familiar with it, is removing the fan clutch. The large nut on the fan clutch unscrews from the water pump shaft. The fan and clutch are removed as a unit. Rent, or buy the tool from Advance or AutoZone. Check out this thread, it says 96 and newer but 95 is very similar: http://www.automotiveforums.com/vbulletin/showthread.php?t=498467 Another tip is to either remove the radiator, or put a piece of 1/4" plywood over it, to protect it during the water pump replacement. Post back when you’re done and let us know how it went. DelCoch 03-21-2007, 06:52 AM My late in the year '95 model doesn't have the large nut on the fan clutch which unscrews from the water pump shaft. On mine it just has the 4 old fashioned 7/16 bolts that hold the fan and fan clutch on. Best to check before running and buying the special wrench. No need to remove the radiator, as I recall I think the top half of the radiator shroud is removable, which is a plus in giving you room to work. Either that or the whole shroud comes out, I can't remember. aleekat 03-21-2007, 10:20 AM Any special tips on replacing the water pump on my 95 Blazer that anyone could share? I see that I'll have to remove the 4 bolts from the fan..anything I'll have to watch out for? There is a note on the frame stating there are air bag sensors in front of the radiator. Will this be a problem when doing this repair? Thanks Disconnect your negative cable for 10mins before starting the work.(Leave it disconnected) Note: If you have a radio with anti-thief code, know the code before you disconnect. blazes9395 03-21-2007, 03:46 PM My late in the year '95 model doesn't have the large nut on the fan clutch which unscrews from the water pump shaft. On mine it just has the 4 old fashioned 7/16 bolts that hold the fan and fan clutch on. Best to check before running and buying the special wrench. The '95 did not have the single shaft connecting the clutch/fan to the pump, it had the 4 studs, withthe bolts, just like DelCoch said. Automotive Network, Inc., Copyright ©2012
