Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Bonneville
Old 03-17-2007, 06:42 PM   #1
pontiacbonnie
pontiacbonnie Normal reputation
coolant level sensor
How do I change the coolant level sensor on a 1994 Bonneville?
pontiacbonnie is offline   Reply With Quote
Old 03-24-2007, 02:50 PM   #2
pontiacbonnie
Re: coolant level sensor
The coolant sensor is located under the upper radiator hose. You'll need to drain the coolant level below the sensor so it can be removed. Remove the electrical connection and then pull the clips up to loosen the sensor from the radiator. The sensor will slide out. Install the new sensor and attach the electrical connection. Add the fluid to fill the radiator.
Bookmarks
Google
Web AF
