Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 03-17-2007, 06:36 PM   #1
phannam
phannam Normal reputation
Wheel noise
I have a 92 4Runner 4WD w/ manual Xmission, 182K miles. It has just started making a whump-whump-whump kind of noise, not super loud, but noticeable at all speeds. Ride is smooth and braking is good. Noise is not coming from the engine, sounds like it’s coming from the back. Noise slows down when the tires slow down. I had 31x1050-15 (BFG All terrain) tires on it, and they were due for replacement, so I had them (Discount) put on BFG All terrain 30x950-15 on (Save a little gas and I don’t need 31s). I thought that would fix the problem but it didn’t-- same noise, same loudness. Someone suggested replacing all the wheels (they are OEM) but I have never banged them up. Any Ideas? Rear brakes? Mecahnical problem in the back? (I am not too mechanical obviously). Thank you.
phannam is offline   Reply With Quote
Old 04-01-2007, 10:48 AM   #2
silversup
silversup Normal reputation
Re: Wheel noise
chk the bearings in the back
silversup is offline   Reply With Quote
Old 04-01-2007, 10:58 AM   #3
Scrapper
Scrapper Normal reputation
Re: Wheel noise
if you take your hand a feel around tire i'f there chopped so to speak sounds like shocks needing replaced because of tires being chopped up..
good luck..
Scrapper is offline   Reply With Quote
Old 04-03-2007, 11:58 PM   #4
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Re: Wheel noise
Try greasing all the drive shaft fittings
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 04-23-2007, 11:30 PM   #5
chachy6959
chachy6959 Normal reputation
Re: Wheel noise
If it gets worse definitely check all the tires. One of mine parted a steel belt inside and created a swollen, weak spot and a noise like you were talking about. That resulted in new tires.
chachy6959 is offline   Reply With Quote
Old 04-25-2007, 04:03 PM   #6
fourwd1
AF -Advisor
fourwd1's Avatar
fourwd1 Normal reputation
Re: Wheel noise
Could be wheel bearing (although they rarely fail), shoes rubbing the drum, differential, etc.
Put the axle up on jackstands and rotate each tire by hand. Locate the source of the noise by feel and sound, left tire? right tire? differential?, etc.
If it's a tire pull it off and rotate the drum, do you still hear or feel it?
If yes, pull off the drum, and repeat.
Get a service manual to help you.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
fourwd1 is offline   Reply With Quote
Bookmarks
Google
Web AF
