Black Projectors
cyberfelon
10-08-2002, 07:15 PM
OK who can tell me where to get these projectors and/or how much they are???
kris
10-08-2002, 07:18 PM
Ebay, and they run about $150-$200
amy@af
10-08-2002, 07:19 PM
he got those off ebay. you can try your luck there...but ebay scares me, and not many things do :licker:
cyberfelon
10-08-2002, 07:22 PM
aight thanks. you know whos car that is??? I got that a while back and forgot whos it was, and also is that the ONLY place cuz i hate buyin stuff off ebay
MyFirst4G
10-08-2002, 07:38 PM
thats CZR's car.... he has a tight car, just get em off eBay, and buy of someone with good feedback, and use PayPal, this way if no merchandise, they will give u ur money back, and paypal will hassle them about it......
mightytexn
Aren't those the lights ci5ic has? He should be able to tell you where to get them and how much they are.
ci5ic
10-08-2002, 07:39 PM
I've got the same ones from www.autodynamic.com
They kick ass.
If you have a hatch, they will require some modification because they are only made for the CRX.
Here's a write-up I did for 4thgenerationcivic.com:
‘88-‘89 CRX Projector headlight installation into ‘90-‘91 hatchback:
CRX headlights will fit in a hatchback, but require some slight modifications… You have 2 options:
1.) You can swap the mounting brackets from the OEM headlights to the projector headlights.
2.) You can use the projector’s mounting brackets and modify the corner lenses to fit.
** Personally, I would recommend swapping the mounting brackets… I didn’t do that, I used the projector brackets and modified the corner lenses, but in hindsight, it would’ve saved me a lot of trouble if I’d just swapped the brackets. **
For swapping the mounting brackets, you should be able to remove all screws/bolts from each set of lights, and swap everything over. Then, when you install the lights, all the bolts should line up, and the corner lenses should fit without modification.
TOOLS/MATERIALS REQUIRED:
= Assorted screw drivers
= Assorted sockets/wrenches/pliers
• Remove front bumper.
- Remove the 2 screws (Phillips) in each front fender well.
- Remove bumper lenses (2 screws each)
- Remove the 2 bolts under the bumper lip.
- Remove the 4 bolts (2 on each side) that are behind the bumper lenses.
• Remove trim piece from below headlights/hood (1 bolt in center, 1 bolt (each side) under headlights, 1 bolt (each side) in corner lens holes.
• Remove OEM headlights (4 bolts each, 2 on top, 1 on side, 1 on bottom)
• Swap the OEM brackets for the Projector brackets.
• Install projectors, all bolts should line up.
• Re-install bumper trim and bumper (reverse of removal).
• Re-install corner lenses.
For using the projectors mounting brackets:
= Dremel tool with cutting disc
= Drill
= Long 1/8” metal drill-bit
• Remove corner lenses (one retaining screw in headlight bracket)
- Remove the 2 screws in each front fender well.
• Install projectors, all bolts should line up properly.
• Test fit the corner lenses. You’ll notice that the corner lens mounting bracket needs to be modified to fit into the projector mounting bracket. Use a dremel tool with a cutting disk to modify the corner lens mounting arm.
• Once the mounting arm fits, you will need to drill a hole in the headlight mounting brackets to accommodate the corner lens retaining screw. Use an extra long 1/8” drill bit and just drill through the hole in the corner lens mounting arm.
• Add a 1/8” metal screw to hold the corner lenses in place…
remember to have your projectors professionally aimed/aligned.
They kick ass.
= Drill
MyFirst4G
10-08-2002, 08:30 PM
no, ci5ic's car is GREEN......
cyberfelon
10-08-2002, 08:35 PM
thanks for the help, Autodynamic lists them under the 90-91 section now witha NEW next to it so i think they make em for them now SWEEET, now all i gotta do is save up $250!!!:(
MyFirst4G
10-08-2002, 08:47 PM
really? that means that eBay will have em soon!!! Sweet! Thanks for the tip! :)
GTA
10-08-2002, 08:54 PM
he never said that the gold car was ci5ic's,
so be nice :)
so be nice :)
ci5ic
10-08-2002, 09:17 PM
It still says 90-91 CRX/Civic, so who knows what it fits. CRX and hatch headlights aren't directly interchangeable, even if they're both 90-91... However, I don't have any experience swapping 90-91 CRX headlights to a 90-91 hatch, so I don't know what would have to be done.
That'd be awesome though.
MyFirst4G
10-08-2002, 09:26 PM
Originally posted by 88CiViC_DX
so be nice :)
i wasnt saying anything wrong............. god damnit, i knew i should have put a damn happy face smily at the end.......... i was just sayin... ya know?
so be nice :)
GTA
10-08-2002, 10:35 PM
:silly2: you should have...:D oh well... just seemed like you were trying to make him feel stupid.
amy@af
10-08-2002, 11:16 PM
CZ_R rules! more pics of his car in the photos section at the site. maybe if he sees us talking about his car...we can drag him back up in here ;)
ci5ic, you rock the block. thank you again for the how-to
Melt
10-09-2002, 12:10 AM
Here are some more projector pics
ci5ic's
http://files.automotiveforums.com/uploads/343204WebDone01.jpg
silver89civic's (yes I know they arent black housing:finger: )
http://mediaservice.photoisland.com/auction/Jul/20027258570538415919227.jpg
http://mediaservice.photoisland.com/auction/Jul/20027258713449314840968.jpg
What ever happened to that guy anyway? he was hella cool.
ci5ic's
